ajoncar
Hey Im just getting started on this this swap was wondering, once the job is finished, will the car run and drive and just throw cels with out the cpu adjustments...
VCDS settings.
Use vag-com and turn the key on. Go to 01-Engine and change the soft coding from
0001 to 0002. Keyswitch to the off position immediately after. Clear all the fault codes,
after running the engine, no faults should return.
or will this thing not be driveable until those are done? Just trying to figure if ill need a tow to my mechanic, or if ill be able to drive it there to get the vagcom work?
VCDS settings.
