plugger
- Joined
- Mar 7, 2007
- Location
- Stony Creek Va. USA
- TDI
- 99 jetta TDI,03 JETTA TDI,94 CHEVY 6.5, 99 DODGE CUMMINS 98 Beetle TDI
I have an 03 Jetta my wife drove in the past. She inherited her Moms car so the Jetta has been parked for a little more than a year with an ocational start and move. Clutch worked fine when parked. My son in law is in need of some economical transportation so we gave it to him. When he started to drive it he complained about how hard it was to shift and getting worse. I checked it out and the clutch is not releasing. I can turn it off and put it in gear and change gears fine but not with the motor running. Changing gears driving is the same without pushing the clutch as it is pushing it.I bled the slave cylinder but did not help. I swapped the slave cylinder this AM with one off a Beetle I have torn down working on and it seems the throw out bearing fork has plenty of pressue on it so I dont think it is broken.After changing the slave cylinder and bleeding I can hear the clutch make a squaking noise when pushing the pedal like it is moving. Started the car and at first it seemed to have fixed it but after a few minuites of running and operating the clutch and gears I am right back to where I started. I am thinking now it may be the master cylinder but looking in my Bentley Manual looks to be a pain to change requiring special tools I will have to improvize. Sorry for the long text. Has anyone else had this experience and found the proper repair. Car has 305K on it and to my knowlege ha never had the clutch changed.
