What's your target price to get all 4 done?Can anyone tell me where to get a good price on replacement injectors. New or rebuilt. I would even consider rebuild kits. Thanks!
You can have peace of mind that DBW's injectors will be MINT! he is very professional and meticulous at what he does. Beware of rebuilds, allot of guys don't have the correct equipment to test flow.What's your target price to get all 4 done?
DBW has rebuilt for $459/4
https://www.dbwllc.net/select-and-order-vw-injectors/
A second hand set on Ebay are in the $120-150 range. I got lucky forCan anyone tell me where to get a good price on replacement injectors. New or rebuilt. I would even consider rebuild kits. Thanks!
+1. I have bought 2 sets from him in the past 2 years. Good stuff.You can have peace of mind that DBW's injectors will be MINT! he is very professional and meticulous at what he does. Beware of rebuilds, allot of guys don't have the correct equipment to test flow.
Might seem cheap now, but if you end up melting a piston it will turn out to be a VERY expensive "savings."A second hand set on Ebay are in the $120-150 range. I got lucky for
$60, had a new set of nozzles installed and springs balanced at a local diesel shop for $120. My understanding is that "rebuilt" is simply shimming the springs to pop at the specified pressures.
I'm sure DBW does a great job and has some very expensive calibration equipment that most don't. Depends on your budget
and expectations.
My $.02,
R*2
