WNCtdi
2004 Jetta TDI 273375 miles, no accidents, lots of new parts, heat and A/C work just as they should, sunroof, strong clutch. Headliner is a bit loose in spots, but intact. Small drivers seat tear. Car has been in North Carolina throughout, so no rust. $3950.00
New parts within the last 6 months (less than 10,000 miles):
Cam
Injectors
Timing belt
Water pump
Thermostat
Wheel bearing
4 new struts
4 new tires (about 1500 miles)
Brake cable
Can text or email images.
Cam
Injectors
Timing belt
Water pump
Thermostat
Wheel bearing
4 new struts
Brake cable
