mannytranny
So a while ago I bought a used VNT 17 from a club member. He claimed it was on his fathers car for 10k miles before he upgraded to something else. I bought it and the turbo sat in my garage for a good year. I just installed it on my 2002 Jetta. Along with the install I added a 1.8T pancake pipe.
When carefully examining the turbo, the shaft play felt (in both directions) felt the same as my outgoing VNT 15 which is in fine shape. I reclocked the VNT 17 and noticed an area on the intake housing area that looked like the turbine wheel had come in contact with the housing. Light scuff marks. Seemed odd, but I'm no turbo expert. Wheel spins freely and all seems well. I install this thing, pop off the Inj pump wiring and crank for a bit to get oil to the turbo. Fire it up and it is silent at idle but makes quite a whine above 1400 rpm. Not really a whistle, definitely more of a whine. According to my boost gauge, it supplies 5 psi at 2000 rpm under no load. I have not yet driven it.
I find this troubling. I'm unsure if it is a normal VNT 17 sound or a bad omen. Everything else appears normal.
Is there a way to check the condition of the turbo?
What does the collective wisdom of the forum say?
Thanks in advance.
Thanks in advance.
