Old February 14th, 2011, 14:04   #1
CMB430
Default Came Home On the Hook TWICE Today!
How I spent my weekend: http://forums.tdiclub.com/showthread.php?t=308001
Today, was another story. This morning it started off great. I did my running around and on the way home I got caught at a red light. When it turned green I started to go and my ESL kicked it! There is NO ice on the road today...it is in the high 40's. I look in my mirror and see a puddle and my drive wheel is not grabbing. I pull off the first chance I get and turn off the car. I pop the hood and there is diesel EVERYWHERE and it ran down the RF tire and all over the place. I call AAA and have it towed to my house. I find that it is the filter housing. I pull the top off and see that the green gasket looks like it did not seat properly. I pull a new one out of the box and install it...checking the torque specs (44 in-lb IIRC) and set it in place. I washed the diesel off of everything and used brake cleaner on the RF to make sure all the fuel was off.
I decide to go get fuel and make sure all is well. The car had been idling for over 40 min at this point, just to make sure the leak did not come back and to dry off all the water. I go get fuel and decide to wash it...so I am in line at the car wash. I see smoke start to come out from under the hood! I shut off the car and get out...it is diesel again. I move out of line and pull into the parking lot. AAA will not pay for this tow unless I take it to a repair shop because it is the same problem. So they call a tow for me and I pay out of pocket to have it brought home.
I called the dealer and of course they do not stock the fuel filter housing. So for $299 plus tax it will be there for me on Wed. I figure I must have either bent the cover, stretched the torx screws (did not have the manual first time I changed the filter so I guessed on the tightness) or Murphy is just a prick.
So that was my Love Day. I assume I can reuse the hoses and clamps for the fuel lines on the new fuel filter housing when I install it. It burns my a** that I have to put more money into the car. The other money spent was to keep it nice...this should not happen but I do not think it was VW's fault.
Is there anything that, when I took the battery out to clean the tray and change the brake fluid, that could have caused the fuel pressure to change by chance? Could the filter housing not be out of spec, but experiencing higher than normal pressure?
NEW: 2011 Frontier
SOLD at 44K miles: 2009 Jetta TDI, 6M, fog lights, protection package.
CMB430 is offline   Reply With Quote
Old February 14th, 2011, 15:55   #2
tdiatlast
Your post implies that the leak is between the top and the FF hounsing. Is that correct? If so, can't you just replace the the top, assuming that it's somehow bent? I would think that you couldn't deform the ff housing (isn't it cast aluminum?). Of course, the obvious issue would be a deformed gasket, but I assume you've already checked that.
Just a thought. Sorry for your trouble.
As for changing the fuel pressure, I can't believe that moving the lines around a bit could change the pressure.
2014 Passat TDI, 2009 JSW TDI DSG (buyback)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
2017 Ford Energi Titanium, purchased 12/15/18
tdiatlast is offline   Reply With Quote
Old February 14th, 2011, 16:04   #3
CMB430
Hello fellow NVA diesel owner. How about that fuel price? I cried when I saw it running on the road...not once but twice. To answer your questions, I find it hard to believe that 2 gaskets could be bad. The part I ordered is the assembly, not just the top, so I will replace the lid and canister. That is where the leak is. Right where the lip / pry point is on the front facing the headlight. It sprayed between those two screws.
Those tires are still running great.
NEW: 2011 Frontier
Old February 14th, 2011, 16:42   #4
DanG144
I think that your fuel return line must be plugged up or something.
The pressure in that fuel canister should only be about 10 psig.
It sounds as if you are building back pressure when your system has high return flow.
Did you remove any hoses from your top?
Are you positive that you are putting your fuel filter in properly? Do you have the two hole or the single hole filter?
Old February 14th, 2011, 16:53   #5
CMB430
I removed no hoses from the filter housing lid when I changed the filter. I have the filter that uses the blue gasket with 4 or 5 holes on top. I replaced all 3 parts plus the silver washer for the top screw that is used to drain the fluid on older models per the Bentley manual. None of the hoses look collapsed or anything and I did not kink them.
I am not an expert VW mechanic but I went to school for automotive tech for 2 years and was a mechanic in the Army...so I have a good idea of what right is.
Your idea of pressure sounds plausible. The first time the fuel started while I was stopped after driving at about 45 mph for 2 miles and slower around town before that. The engine was warm. It did NOT leak one drop while idling for 40 minutes in my driveway nor did it leak on the 5 mile trip to the fuel station as I looked when I stopped to pump. It started after I drove in 2nd gear around the building to the car wash and was stopped in line. Is there any connection?
NEW: 2011 Frontier
Old February 14th, 2011, 17:04   #6
DanG144
There is a nipple on top of the filter that must align with a dimple in the top of the fuel canister. This is easy to miss, and if it is not aligned properly perhaps the return line can get blocked?
Old February 14th, 2011, 17:06   #7
DanG144
Is the gap around the top flange evenly drawn down all the way around?
Old February 14th, 2011, 17:08   #8
CMB430
Okay. The Dealer said when I ordered the part there was no return since it is a special order...I find it hard to believe that half of what I order from them (belt, fog light bulbs to name a few) are special order, but it is what it is. So either way now I am replacing the housing as I just may have messed up the screws on the first change at 20K. I cannot answer your question, but I do not remember taking notice of exact positioning of the filter in relation to the lid. Thanks for the tip and on Wed I will be sure to line it up exact.
NEW: 2011 Frontier
Old February 14th, 2011, 17:40   #9
tdiatlast
PM sent
Old February 14th, 2011, 18:26   #10
lou95gts
TDI(s): 2010 Jetta
Fuel Economy: See sig
Remember, the top fuel canister seal is installed on the lid not the canister body as it appears in the Bentley manual. Found this out the hard way myself. Went for a drive and started shooting diesel out after about 20 min.
lou95gts is offline   Reply With Quote
Old February 14th, 2011, 18:29   #11
lou95gts
TDI(s): 2010 Jetta
Oh yeah, always use petroleum jelly (Vaseline) on all seals in a fuel system including the one for the fuel filter.
Old February 14th, 2011, 20:43   #12
Mike in Anchorage
Mike in Anchorage's Avatar
I also had this happen with my 20 k mi service & filter replacement. In the summer, I have no reason for the ESL to turn on, but it was amazing how slick the tire got sitting at one red light and how much fuel ended up on the parking lot pavement!
If you have not checked the alignment as specified by DanG144, you'll get this mess. If that's all it is, you have not damaged anything and you can reset & go. Cleaning up that mess is not fun.
~ I'm selfish, impatient and a little insecure. I make mistakes, I am out of control and at times hard to handle. But if you can't handle me at my worst, then you sure as hell don't deserve me at my best. Marilyn Monroe
2015 Tornado Red Golf TDI Sportwagen SE, new on 2 SEP 2017, DSG, big sunroof. Lovin it!
Mike in Anchorage is offline   Reply With Quote
Old February 14th, 2011, 20:51   #13
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Did you do this?
The huge O-ring goes on the LID and then the lid is installed on the canister body. Lube the O-ring with diesel fuel.
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old February 15th, 2011, 03:51   #14
lou95gts
TDI(s): 2010 Jetta
Yes, that's correct.
Old February 15th, 2011, 13:49   #15
CMB430
Well, I f***ed that up. I put the seal inside the canister, positioned it as best I could then slowly tightened down the lid. When I took the old one out, it was not on the lid. I suppose that is why I did it that way. I am not able to remember what I did the first time...but what ever way it was it worked. I will make sure the new seal is wet (like any oil filter gasket/o-ring/seal) and install it on the lid. Since VW will not take the part back, I will just replace the whole housing.
My main thing is...can I reuse the hoses and, mainly, clamps, that feed / remove the diesel from the fuel filter canister? Or, do they have to be replaced?
NEW: 2011 Frontier
turbo issue? cel came on driving home from work today ryanhorlacher TDI 101 2 December 3rd, 2010 14:55
Golf MKVI interior lighting issue coming home and leaving home options missing Marlyece VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 6 April 3rd, 2010 12:37
Driving home from Roanoke today... TDI Believer VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 1 February 27th, 2010 18:45
fuel transfer pumps for home small home storage 03_01_TDI Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 21 August 18th, 2005 06:52
Brought It home Today!! Dezelduber VW MKIV-A4 TDIs (VE and PD) 6 October 19th, 2000 17:48
Page generated in 0.22230 seconds with 11 queries
[Output: 126.89 Kb. compressed to 106.04 Kb. by saving 20.85 Kb. (16.44%)]
