Climatronic issues while reversing
Nebelwerfer
Canuckistan
2012 Passat TDI
I've noticed that now when I reverse the car, the Climatronic HVAC doesn't switch to internal recycling of the cabin air. Initially noticed it when I smelled the scent of DEF while reversing on a rather chilly day (-35C).
Even in warmer temperatures it doesn't seem to be functioning.
Using the switch manually works just fine.
Any idea what it could be? There have been no codes thrown either, however, I don't have access to VCDS and only have a ScanGuage 2.
Regards
jck66
Greenwich, CT, USA
12 Passat SE / 14 BMW 535d
I'm not sure I ever noticed my 2012 doing this (SE trim with climatronic). Was this a feature for the SEL (highly optioned) models only?
compu_85
Gadget Guy
La Conner, WA
... None :S
Some of the cars will turn on recirc when shifting into R. I'd guess that it's not doing it because it's so cold outside.
-J
Locoelectrician
Ohio
2015 Passat TDI SEL, 2015 Golf SEL Sportwagen, 2005 Jetta TDI, John Deere 355D
-J
Also when you use the windshield washers.
