nhraracer90
Hello,
I believe that I experienced the intercooler icing problem today. Started the car up to run for a few mins and then shut it off. I went to start it up again about 10 minutes later and it started, then stumbled. So I tried to restart it and it acted like a dead battery, at that point I believe I had a problem. So I jacked the car up and pulled the intercooler hose off on the passenger side and water came out.
is it safe to put the intercooler hose back on a start the vehicle up? Do I need to drain the water from anywhere else?
I am assuming that I should invest in the cold weather intercooler kit?
I have a 2010 Jetta sedan. Thanks!
