lincolndj
Hi guys, first time poster on here, as I’ve just bought a 2003 B5.5 Passat 1.9,
On driving it home from the garage I bought it from, I noticed the engine not warming up (never went above 55°c), so assumed either stat or CTS. There is no dash warning lights and no fault codes showing on VCDS.
Next morning, with engine cold I compared the ambient and coolant temps with VCDS (should be close with a cold engine), ambient was about 18°c and coolant was around -13°c which accounted for the approx. 30-35°c short-fall to 90°c on the dash.
Also, the temp didn’t go up after driving hard then being stationary for a while (which if it was the stat the temp should at least rise when stationary and engine running – unless a fan is stuck on too?!)
Took car back to where I bought it from and they’ve replaced the CTS. But the car didn’t really get any warmer when driving back home so now I’m not sure what else to check. (Would just take back to garage but it’s a 2 hour+ round trip, if I can diagnose myself first it may save more trips)
Are there 2 different temperature sensors? Eg one that turns the fan on/off and another for the ECU/gauge? What else should I check in VCDS? The garage replaced a sensor that looked near the bottom of the rad, below alternator.
Also, any tips on how exactly the control logic works? Eg from a cold start, with A/C switched off, should any fans be running from the off?
Cheers, Adam.
Cheers, Adam.
