So I spent some time in the maintenance manual last night and finally found the fluid call out. I don’t know why I couldn’t find it when I looked before but the VW P/N for the fluid is G 052 171 A2.
Anyone know the spec or viscosity of this fluid?
I am approaching 50k miles and just last weekend installed a new Sachs SRE clutch and DMF flywheel, Sachs SRE metal slave cylinder, new master cylinder, stainless braided clutch hose, aluminum bleeder block without the internal restrictor. I **** canned the stupid clutch pedal spring while I was at it too. I absolutely hated the way there was zero feel/feedback to the stock setup. I couldn’t feel when the clutch was starting to engage and would sometimes stall the car because of that, or slip the clutch at start off sometimes when trying to start off quickly due to oncoming traffic. With my current set up the clutch engagement is very predictable and there is enough pedal feel/feedback that accidentally stalling the engine or slipping the clutch doesn’t happen. My car is SO MUCH more enjoyable to drive!
