cocteau104
- Joined
- Oct 25, 2002
- Location
- Columbus-area, Ohio
- TDI
- 2005 Passat GLS TDI Variant; 2002 Golf TDI 5-spd (RIP)
So, I know I've been creating tons of posts on this board, but my car is a little finnicky. Last spring, on my way to Connecticut, the car suddenly stopped being able to accelerate above 65 MPH once warm. I took it to the dealer, they replaced the turbo and intake manifold under warranty. No more cutting out in power, but power in general seemed to be down. Took it back, and they changed the EGR sensor. My warranty has since run out and the car's power is intermittently lower than it should be.
Now, I shift early but have since abandoned the practice. I don't thik my engine's problem is crud in the manifold because it was recently replaced (although it doesn't look new). I don't think it's the MAF sensor ebcause I don't have the drastic symptoms that are associated with that issue. Still, I don't know what it is.
I don't have the sudden cut in power around 4K rpm that the car had when it was new, and I don't have quite the low/mid RPM shove that I used to have either. I feel like the boost is low. What could it be?
Also, I've lost two or three MPG. Please advise.
