Old June 23rd, 2020, 08:54   #1
Aquaticmind
Aquaticmind's Avatar
Location: Wheeling, WV via Athens Georgia via, Bainbridge Is. Wa, via Carbondale IL, via Asheville NC
Fuel Economy: good
Default stripped slider brake slider pin mount
Hi folks,
I need to insight here.
I was working on the front brakes and getting everything back together and the threads on the mount for the slider pin for the front brakes stripped out on the steering knuckle.
No I was not torquing on them like a mad man, I know the the torque spec is pretty low.
So.. what do I do? Can this be helicoiled?
Cheers
2003 Wagen, 2" lift, auto front springs, panzer plate, pp520 injectors, RCII+, ASR
Aquaticmind is offline   Reply With Quote
Old June 23rd, 2020, 09:34   #2
Mongler98
I dont see why not. Helicoil it with come red lock tight. Let dry. Tap it out to clear threadlocker.
Old June 23rd, 2020, 09:54   #3
eddieleephd
Fuel Economy: 38mix / 47@70-75
I've used a slider specifically designed to tap it out. They're a pita but they work.
Sent from my moto g(7) power using Tapatalk
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, Bosio DLC 1019's PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is online now   Reply With Quote
Old June 23rd, 2020, 10:03   #4
Aquaticmind
Fuel Economy: good
Thank you Eddie, Can you give any more details about the slider specifically designed to tap it out?
....Found one that should fit and the parts store had it. I hope it works.
Old June 24th, 2020, 18:34   #5
tdidieselbobny
tdidieselbobny's Avatar
I think IDParts has some that are oversized, I guess this a common problem...luckily, not for me...
97 Passat TDI-420,688 miles,totalled by 86yr.old lady-gone,but not forgotten:mad-'15 Silk Blue Golf Sportwagen w/DSG, 50k miles....'16 Kubota BX1870 MMM/FEL, 260hrs-And now an '03 Jetta TDI 5spd w/ 452k,RC2,Sprint 520's,Dieselgeek short shifter , totaled 10/13/19 by a stupid deer, back alive 11/4/19....
tdidieselbobny is offline   Reply With Quote
Old June 25th, 2020, 02:14   #6
Tdijarhead
I recently refreshed the front end of one of my daughters boyfriends car. An 03 Jetta gasser, someone had used an aftermarket slider to repair the stripped threads. The threads on the slide looked oversized and self tapping.
Old June 25th, 2020, 03:26   #7
oilhammer's Avatar
Fuel Economy: fantastic
I have seen that before, not really sure how people do it, but it must not be very hard. There is an aftermarket oversize "fix" for that, but you should know that those seem to be limited to that one time install, and after that they never really seem to screw in as nicely as the originals. In which case, the only thing is a new carrier assembly.
Good news there, is that there are aftermarket already assembled carriers available... I know Moog sells them... I am sure they are of Chinesium but they seem to work OK. They come with new wheel bearings, hubs, etc. already installed and ready to go.
Another option is to use this misfortune to upgrade to the larger brakes in front.
www.cardocautomotive.com
Old June 25th, 2020, 11:27   #8
Lex4TDI4Life
Lex4TDI4Life's Avatar
I have had this happen and yes, the oversized slider is a one-time-only fix. Last time it happened, I installed a Time-Sert and it has held up great. Helicoil will work, too.
2001 Golf TDI 5 spd
RC2, Bosch T4-764 injectors, OMI, SBC Stg 2 Clutch, Koni FSDs, TT LCA Bushings, The Mystery Bar, Dieselgeek Panzer Plate, Elephant Hose, DG Race Pipe, Autometer Cobalt Boost Gauge, Boostvalve,Fumoto Valve, Mufflerectomy, Scangauge II
Lex4TDI4Life is offline   Reply With Quote
Old June 29th, 2020, 03:24   #9
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
I tried over and over again to helicoil these and I could never ever get the pin straight. Best bet is a new knuckle
runonbeer is offline   Reply With Quote
Old June 29th, 2020, 20:12   #10
[486]
TDI(s): 02 golf ALH
I have very good luck helicoiling them
m9x1.25 IIRC
[486] is online now   Reply With Quote
Old June 30th, 2020, 03:09   #11
https://www.idparts.com/oversized-br...4-p-10230.html
Used one on my son's Golf last winter. One of us cross-threaded the pin on a previous repair. Working fine.
These are also available at Autozone if you don't want to wait for it to ship. Use the manufacturer's PN in our product to request.
2002 Jetta wagon, 412K, RC3+; 1993 Mercedes-Benz 300D 2.5, 199K; 1997 Passat, 289K; '99.5 Golf, 262K; 2011 335d, 64K; 2015 Golf Sportwagen, 14K. Principal, http://www.idparts.com
Old June 30th, 2020, 03:39   #12
Tdijarhead
That is exactly what I found on my daughters boyfriends Jetta. Id never seen them before.
Brake job gone bad - slider bolt receiver stripped!! JoshWagen VW MKIV-A4 TDIs (VE and PD) 15 February 9th, 2017 21:38
Brakes: Stripped slider pin hole UhOh VW MKIV-A4 TDIs (VE and PD) 15 April 19th, 2016 11:46
Seized slider pin - replace caliper carrier? jfd3220 VW MKIV-A4 TDIs (VE and PD) 5 October 15th, 2013 16:50
Rear brake slider pins pakhribas TDI 101 4 September 24th, 2008 12:04
Siezed Slider Pin Diesel_Knievel VW MKIV-A4 TDIs (VE and PD) 11 August 16th, 2004 20:49
Page generated in 0.15044 seconds with 12 queries
[Output: 112.25 Kb. compressed to 94.68 Kb. by saving 17.57 Kb. (15.65%)]
