jchintall
- Joined
- May 6, 2002
- Location
- Delanco, NJ
Hello,
The engine light come one today. The following is the VAG-Com print out for this single fault. I have omitted several lines of the VAG-Com report since it has no bearing on this fault. In fact this was the only fault found.
This Touareg has 20265 miles on it. Can someone tell me what and where is the reductant pump. I usually use the manual but there is no manual available for this TDI.
Thank you for your help!
John
Wednesday,26,December,2012,15:51:38:13299
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Chassis Type: 7P6
01-Engine -- Status: Malfunction 0010
Address 01: Engine (J623-CATA) Labels: Redir Fail!
Part No SW: 7P0 907 401 J HW: 7P0 907 401 E
Component: 3.0TDI EDC17 H17 0002
Revision: 56H17---
Coding: 292A4012233600050000
Shop #: WSC 37264 272 173949
ASAM Dataset: EV_ECM30TDI0117P0907401J 001002
ROD: EV_ECM30TDI0117P0907401J.rod
VCID: 3669344389748EA8CB9
1 Fault Found:
9641 - Control Circuit for Reductant Pump 1
P208C 00 [237] - Short to Ground
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 14318 km
Date: 2012.07.22
Page 1
John
Chassis Type: 7P6
Revision: 56H17---
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 14318 km
Date: 2012.07.22
Page 1
