Hello,
My name is Chris and i have an seat leon 1.9 tdi, engine bxe, 2008
some items on my car:
GTB2260VK Turbo Kit
FMIC with 57mm Custom Pipe Work
EGR Delete
Race PD Injectors with Bosio R783 Nozzles
4 BAR MAP Sensor
3" Downpipe
76mm Exhaust System with Borla Resonator
Mocal Oil Cooler
Mocal Diesel Cooler
Oil Catch Tank
Motul 300v Power Oil
The car here have 240 hp and works very good
I plan to upgrade the car on May with this
Race Camshaft Kit
Ported Head
33mm Exhaust Valves
What i do:
-Change 2 pistons, put Competition Spec Bearings, make linear plan to cylinder gasket and take aprox 0,10 mm, my car have head gasket with 2 holes 1,53 mm and i put with 3 holes 1,61 mm, ported head and cleaning, and the new race camshaft kit, modified for 33mm Exhaust Valves
After i put all of this to my car have THE GREAT AND UNSOLVED PROBLEM is that he lose power from 3500 rpm and receive this error when tested with foot on the floor on acceleration
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 119620 km
Time Indication: 0
Date: 2000.00.00
Time: 05:15:42
Freeze Frame:
RPM: 3717 /min
Speed: 131.0 km/h
Load: 100.0 %
Voltage: 13.91 V
Bin. Bits: 00001000
(no units): 3344.1
(no units): 2402.1
on 3700 rpm the engine enter in limp mode !
Please help me to solve this problem, and i will pay 100 euro thru paypal for the one who discover the problem.
What i test to solve but no result: all injectors, change the turbo vacuum actuator, test for leaks, test for exhaust manifold pressure, test for boost:
Engine Speed Boost Pressure Boost Pressure
(G28) (specified) (actual)
/min
2016 1428,7 1460,1
2079 2072,4 1538,6
2142 2480,6 1805,5
2247 2621,9 2150,9
2394 2496,3 2260,8
2331 2684,7 2464,9
2709 2747,5 2606,2
2667 2653,3 2480,6
2835 2716,1 2559,1
2856 2888,8 2606,2
2940 3014,4 2841,7
3129 3124,3 2857,4
3192 3140 2810,3
3255 3202,8 2778,9
3318 3234,2 2778,9
3402 3249,9 2731,8
3444 3281,3 2669
3486 3281,3 2606,2
3549 3297 2606,2
3570 3312,7 2559,1
3633 3328,4 2527,7
3654 3328,4 2512
3675 3344,1 2512
3696 3359,8 2464,9
3717 3359,8 2417,8
3738 1507,2 2417,8
3759 1444,4 1648,5
Here is my car, please help me:
Here is the video when the car enter in limp mode, tested on 4th gear with maximum pedal acceleration, vcds + EMP gauge
http://www.youtube.com/watch?v=JHjh_X5YcC8&feature=youtu.be
GTB2260VK Turbo Kit
EGR Delete
4 BAR MAP Sensor
3" Downpipe
Mocal Oil Cooler
Mocal Diesel Cooler
Oil Catch Tank
Race Camshaft Kit
Ported Head
33mm Exhaust Valves
What i do:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 119620 km
Time Indication: 0
Date: 2000.00.00
Time: 05:15:42
Freeze Frame:
RPM: 3717 /min
Speed: 131.0 km/h
Load: 100.0 %
Voltage: 13.91 V
Bin. Bits: 00001000
(no units): 3344.1
(no units): 2402.1
/min
2016 1428,7 1460,1
2079 2072,4 1538,6
2142 2480,6 1805,5
2247 2621,9 2150,9
2394 2496,3 2260,8
2331 2684,7 2464,9
2709 2747,5 2606,2
2667 2653,3 2480,6
2835 2716,1 2559,1
2856 2888,8 2606,2
2940 3014,4 2841,7
3129 3124,3 2857,4
3192 3140 2810,3
3255 3202,8 2778,9
3318 3234,2 2778,9
3402 3249,9 2731,8
3444 3281,3 2669
3486 3281,3 2606,2
3549 3297 2606,2
3570 3312,7 2559,1
3633 3328,4 2527,7
3654 3328,4 2512
3675 3344,1 2512
3696 3359,8 2464,9
3717 3359,8 2417,8
3738 1507,2 2417,8
3759 1444,4 1648,5
