Old September 13th, 2018, 08:47   #61
I'd go with Koni Yellows or Special Actives. The damping on OE struts and shocks may be inadequate. You could try and source Alltrack OE dampers but I'm not sure rear fitment is the same. I'd replace front and rear mounts, but you should be able to swap over the bump stops and boots.
2002 Jetta wagon, 373K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 286K; '99.5 Golf, 259K; 2011 335d, 56K; 2015 Golf Sportwagen, 10K. Principal, http://www.idparts.com
Old September 13th, 2018, 14:45   #62
jdstrd
I did this lift with Koni FSD's. Rides awesome.I added Firestone Coil Rite bags to it also.Stock suspension would be pretty harsh, would be my guess.
jdstrd is offline   Reply With Quote
Old September 13th, 2018, 22:57   #63
Keep in mind that Koni has re-branded FSDs to Special Actives.
Old September 14th, 2018, 04:14   #64
740GLE
does idparts carry/get a hold of konis Special Actives for the mk7? specifically the 55mm front struts?
Old September 14th, 2018, 08:52   #65
We have fronts and rears on order, arriving soon. I believe the TDIs use 50mm struts, however, so we won't be stocking the 55s.
Old September 14th, 2018, 11:28   #66
Chris Bell
Peter, are the Special Active rears on order for the twist beam or IRS? Just following up on a previous inquiry about the unavailability of the rears.
'15 GSW SE 6MT
'01 Golf 5MT
'97 Passat sedan
'96 Passat variant
'99 BMW M3 Cabrio
Chris Bell is offline   Reply With Quote
Old September 14th, 2018, 11:50   #67
tdi_hatch
Thank you sir! I'll definitely replace the mounts. I'm thinking I'll go with the special actives.
I'm seriously considering this. How long did everything take you? Did you install on a lift?
tdi_hatch is offline   Reply With Quote
Old September 14th, 2018, 11:55   #68
Chris, we're ordering twist beam rear Special Actives. We were ready to special order them from Koni, but they decided to stock them in the US. We don't have an arrival date yet.
Old September 14th, 2018, 12:46   #69
Chris Bell
Great, thanks!
'15 GSW SE 6MT
'01 Golf 5MT
'97 Passat sedan
'96 Passat variant
'99 BMW M3 Cabrio
Old Yesterday, 11:17   #70
fase2000TDI
Fuel Economy: 52, 45 38
I wonder how much different Bilstein TC's all around with the AllTrack springs would handle.
Is the MKVII rear wagon shock different than the MKVII Golf hatchback shock like in the MKIV's? If not it looks like Rock Auto already has the rears available - but no Bilstein for the fronts.
Peter - what's your thoughts on the MKVII control arm bushings? They look to be the same style as the MKIV with the thinner areas. Any VW/Audi cars that use the same size bushing like we did on the MKIV's and the TT control arm bushing?
TDI service available - timing belts, clutch jobs, cv joint rebuilds, engine rebuilds, maintenance, low power diagnosis, suspension. DSG service $180 Have CAN VCDS for CR TDI's PM here, call or email JeremyTDI@yahoo.com (401)-919-0466 Quotes available, very fair rates
fase2000TDI is offline   Reply With Quote
Old Yesterday, 12:45   #71
Don't know how the car will handle with different dampers. One thing I've learned is it's a mistake to extrapolate how one car handles with a certain damper to another platform. It usually doesn't work out. For example, I've found that MKIII cars ride great with TCs, MKIVs ride more harshly, IMO. So you'd have to try it and see what you think.
We haven't investigated the bushings yet, but VW seems to have more model-specific suspension components now than previously. I suspect Rock Auto shows two rear shocks because one is for IRS and one is for the beam axle. I don't think there's any difference in the rear shocks between the GSW and Golf TDIs.
Old Today, 07:42   #72
740GLE
Lots of MBQ LCA stuff can be swapped with S3/R including cast subframe rather than the stamped steel.
I believe Whiteline and Super Pro make replacement LCA, that should bolt up to the 50mm knucles of the Golf.
Best way to get 1-2" lift on 15 sportwagen hause VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 1 July 3rd, 2017 05:09
2" lift springs "Custom Suspension in Canada" anyone using these? eddieleephd VW MKIV-A4 TDIs (VE and PD) 0 February 24th, 2017 11:19
H&R springs for MK7 Sportwagen TDI Ruso Turisto VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 93 December 12th, 2016 18:49
Metalnerd Lift kit + VR6 Springs Will give about 2" Total Lift tothemax Private TDI Items for Sale/Wanted 5 December 9th, 2012 06:04
Almost 2" of lift with 1 " Metalnerd Kit with VR6 springs tothemax Upgrades (non TDI Engine related) 20 August 24th, 2008 17:04
Page generated in 0.14249 seconds with 12 queries
[Output: 113.88 Kb. compressed to 96.54 Kb. by saving 17.34 Kb. (15.23%)]
