Notasunbeam
Hello all. Newb here. I have a 2001 vw new beetle 1.9l tdi 5sp manual
Problem:
I stalled the engine myself, on an errand.. From then on, would crank but not start.
Codes: P1562 quantity adjuster limit reached,
P3130 glow plug circuit.
The glow plug one was explained by a disconnected glow plug. Glow plugs good and 12v at the Connectors.
When it cranks its not even trying to start. I checked the air shut off, its not stuck shut. Lotta gunk in there tho.
There isnt 12v to the fuel shut off solenoid with ignition on. It clicks open when I jumper to the battery.
Tried priming it. poored reg gas in the intake. , still cranked freely no start.
Glow plug and check engine light come on when ignition is switched on.. Should I check relay 109 anyway? next I was going to check valve timing. And possibly throttle?
Would there be related codes if it had jumped time? I would expect to
see something- crank pos sensor or something.
Any advice would be appreciated.
Problem:
