Doughglass
- Joined
- Sep 13, 2017
- Location
- Shelby Michigan
- TDI
- 14 sportwagen 6speed, 03 wagen 5speed, 00 new beetle 5speed
Recently bought a 2000 beetle that someone said would not start and had ‘given up’ on. I trailered it home, put new battery in and it started and ran good!
Looking into it, I noticed soot in the coolant, so I hoped it might be an egr cooler issue. I deleted the cooler, cleaned the intake and pulled the oil pan due to cracks and welded it up. Reassembled the engine, added oil and coolant and took it for a spin, limp mode! Replaced turbo actuator, n75, check valve, and hoses. Car runs like a top now. Drove it to work and home today, almost 300mls. Heat didn’t work good. Popped the hood when I got home and noticed coolant reservoir level was extremely high and head is wet around glow plugs 1 and 4. Oil is clean and correct level. I’m guessing they overheated it by running out of oil? Possible to crack head? Or just blow a gasket? Has anyone seen an issue similar? Thanks.
