Old February 17th, 2020, 19:48   #16
wonneber
Originally Posted by B3achbum View Post
Make sure your battery is Solid charged. You're not going to get injection before 200 rpm.
I knew it was higher then 188 RPM, just wasn't sure how much.
wonneber is offline   Reply With Quote
Old February 20th, 2020, 18:55   #17
Riveroffroad
Fuel Economy: .....
News
-pull go again so I could reset and double check timing
-with battery on charger ran until diesel mist(good flow)
-put gp in 1 at a time
-started on 1 gp, cyl 1 fired
-started with 2 gp, cyl 1,2 fired
-started with 3 gp, cyl 1,2,3 fired
-all 4 gp in nothing
-repeated process till 3 cyls firing, it eventually lost prime and stopped firing
Riveroffroad is offline   Reply With Quote
Old February 25th, 2020, 07:21   #18
Riveroffroad
Fuel Economy: .....
So it was injector 4. I could get it to run on 3 cyl
But once I put in gp for cyl 4 it would lose prime
So theory was seal in injector was allowing the piston to send air in the system
Swapped 4 good injectors in and varooooom
BEW Crank Spocket Pinning - Dadwagon TDI 101 7 October 8th, 2018 11:53
BEW Crank Seal. To change or not? smoan VW MKIV-A4 TDIs (VE and PD) 5 November 15th, 2017 19:27
How to crank BEW engine without letting it start? dilkie VW MKIV-A4 TDIs (VE and PD) 6 April 1st, 2016 23:41
How to crank BEW engine without letting it start? dilkie VW MKV-A5 Golf/Jettas 4 March 30th, 2016 04:41
ALH vs BEW crank bolt? turbotec VW MKIV-A4 TDIs (VE and PD) 1 March 15th, 2013 10:19
Page generated in 0.13527 seconds with 13 queries
[Output: 58.63 Kb. compressed to 53.47 Kb. by saving 5.16 Kb. (8.81%)]
