Enormex
Hello,
I bought a Seat Ibiza 1.9 TDI 1998. It was starting fine for some time but then after a long drive it was unable to start again. We had to push start it to get back home.
The starter was tested and is working fine, the relay is clicking when turning the key to ignition position. Relay works fine, we tested. Line from starter to fuse box is good. Today it actually cranked for a second after moving the fuse box and pushing the key to ignite. I guess it is a bad connection at the fuse box?
There is so many wires behind the fuse box so I find it really hard to check the wires. Any suggestions?
Thanks and best regards
