ABS Codes - 2015 Passat - New Sensor
Strider17
Hamilton, Ontario, Canada
Beetle(sold) MK4 Golf TDI(sold) Mk4 Jetta TDI(parted out) MK4 Golf GTI w/ALH swap (built then parted out) 2015 Passat TDI Highline (current)
Hi there, I have an issue with my abs sensor.
2015 Passat TDI SEL Manual
Car was running good with no lights on or codes. but needed brakes. While I was doing brakes the rear bolts needed some heat since they were seized.
While i was heating up the bolts the rear left connector /abs sensor got damaged (fried)
I ordered this speed sensor from auto parts way and fixed the connector as well :
https://www.autopartsway.ca/partdet...mponents/abs-wheel-speed-sensor/pagenum1/tabs
After everything was installed I cleared all codes but these keep coming up as soon as I pick up some speed.
Is there something I need to adapt or is there a special sensor for my Passat? I can’t see the new sensor being bad as well.
Here is the vcds scan.
Tuesday,11,September,2018,18:45:28:38813
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 18.2.1.2
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: 1VWCV7A32FC075349 License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F 52
56 62 72 77
VIN: 1VWCV7A32FC075349 Mileage: 136410km-84761miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CVCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 AE HW: 04L 907 309 K
Component: R4 2.0l TDI H20 9288
Revision: 8AH20---
Coding: 01190012832410081000
Shop #: WSC 93229 999 00000
ASAM Dataset: EV_ECM20TDI01104L906016AE 004018
ROD: EV_ECM20TDI01104L906016AE_004.rod
VCID: 6CDDD8C7871C6A24EB-8038
1 Fault Found:
17158 - Databus
U1123 00 [036] - Received Error Message
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 136400 km
Date: 2018.09.11
Time: 18:24:54
Engine speed: 1415.50 /min
Normed load value: 0.0 %
Vehicle speed: 24 km/h
Coolant temperature: 55 °C
Intake air temperature: 51 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.100 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coordinator: brake fault status-Bits 0-7: 4
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: -0.108 m/s²
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: C54BC0F5492900FFA30E03E892220042A1100012
Shop #: WSC 09003 957 00200
VCID: 040D9067878C826403-8050
2 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 225
Mileage: 136400 km
Time Indication: 0
Date: 2018.09.11
Time: 18:24:54
Freeze Frame:
Count: 0
Count: 0
Count: 12800
Count: 69
Count: 50456
Count: 255
Count: 1018
Count: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 226
Mileage: 136415 km
Time Indication: 0
Date: 2018.09.11
Time: 18:42:01
Freeze Frame:
Count: 3
Count: 2
Count: 4096
Count: 16390
Count: 44032
Count: 0
Count: 1022
Count: 0
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0356931623
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSYPQ35G_A02_VW31.rod
VCID: 377737AB8EDA19FCD6-8062
No fault code found.
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 561 907 044 AR HW: 561 907 044 AR
Component: Climatronic H03 0808
Revision: 00001K01
Coding: 0050019002
ASAM Dataset: EV_ACClimaBHBVW411 A01001
ROD: EV_ACClimaBHBVW411_VW41.rod
VCID: 67D7A7EB9EFA497C86-8032
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0174
Revision: BL122001
Coding: EF200E7BC82B2AD4088800003600850806F1A08655B005B064804000AC70
VCID: 78F5F497CB44D6841F-802C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 181214 05 54 0403
Coding: 02300A
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 500 0975
Serial number: 003LZD059R8Z
Coding: 00004D38
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 72E1C6BFA538BCD421-8026
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y150001AU2G0W
Coding: 303047
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME30052C4BZZZU
Crash sensor for side airbag: front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME59042C4BZZZ+
Crash sensor for side airbag: rear: driver side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME03437933ZZZL
Crash sensor for side airbag: rear: passenger side:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME5E1E0934ZZZ/
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME45597F31ZZZ0
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME6E407F31ZZZ2
1 Fault Found:
9483008 - Seat Occupied Recognition
B10B3 00 [137] - Function Restriction due to Implausible Message(s)
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 226
Mileage: 136400 km
Date: 2018.09.11
Time: 18:25:10
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 1K5 953 521 BR HW: 5K0 953 569 AH
Component: LENKS.MODUL 016 0162
Revision: FF010042 Serial number: 20141127201696
Coding: 000A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7EF9E28FE160E8B455-802A
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-8LP H07 0023
Serial number: 00000000000001012205
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 870 E HW: 561 920 870 E
Component: KOMBI H05 0813
Serial number: 00000000000000
Coding: 331C01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 1B3FCB1B12325D9CD2-804E
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM
Component: J533 Gateway H55 1653
Revision: H55 Serial number: 09021503000189
Coding: 461000
VCID: 00059C7793949E4427-8054
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0813
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6AD1DEDF8DE8741499-803E
Address 2B: Steer. Col. Lock (J764) Labels:| 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 14000352262004
Coding: 4100000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 30650CB76BB4CEC497-8064
Address 2E: Media Player 3
Cannot be reached
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 561 959 760 B HW: 561 959 760 B
Component: MEM-FS H04 0183
Revision: AA000000 Serial number: 00000133060595
Coding: 00581B0000000000000021010100202020202120202020
VCID: 2241F6FF3D586C5411-8076
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C0 035 684 Q HW: 3C0 035 684 Q
Component: RNS-MID H27 5378
Revision: AB001001 Serial number: VWZ6Z7R7009152
Coding: 24090042010000A6000B
VCID: 316309B368BEC7CC98-8064
Subsystem 1 - Part No: 7L6 919 859
Component: NAR V9 8213
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0009280292
Coding: 0405FD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1C3DC807173C5AA4DB-8048
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14102630150210085958
Coding: 800000
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 215 3501
Revision: 00H22000
Shop #: WSC 01357 011 00200
VCID: 3973319370CE0F8C20-806C
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 11
Mileage: 136400 km
Time Indication: 0
Date: 2018.09.11
Time: 18:24:55
Freeze Frame:
Voltage: 14.13 V
DU
Temperature: 28.0°C
RPM: 1402 /min
Speed: 23.0 km/h
Speed: 23.0 km/h
Count: 0
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0034772
ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
ROD: EV_AudioVerst10KanalSTT3.rod
VCID: 2855E4D7536486044F-807C
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1653
Coding: 01030108
VCID: 6FE7CFCBBE0A913CCE-803A
Subsystem 1 - Part No SW: 561 959 591 A HW: 561 959 591 A
Component: J245 P05 9BA3 H08 0005
Serial number: 53388786011417500009
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 009 0005
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0009292415
Coding: 0405FC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D3BC5030C2653AC2C-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14202631150203095354
Coding: 800000
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666727512
Coding: 0A10030080010110
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI.rod
VCID: 326106BF65B8FCD4E1-8066
End-------------------------(Elapsed Time: 03:39)--------------------------
thundershorts
west chester pa
2015 passat tdi sel premium 2015 golf s tdi gls tdi b5.5, 2002 eurovan,Peugeot 505 td,Citroen cx25 prestige
Lppoks like you installed not compatable sensor.
740GLE
NH
Where did you buy the sensor?
Shopdap and Idparts are good sources of OEM or OEM compatible units.
Strider17
It’s a ATE speed sensor from autopartsway from the link above.
I don’t understand how they can be no compatible... dealer wants over 100 bucks for the sensor
Strider17
Picked up a vw dealer sensor. It’s an ATE as well. Wiring is good too. Time to change the wheel bearing
Strider17
I went to get a wheel bearing but before I went to put it on I went ahead and got a oem vw sensor.
Also I noticed it is the exact same ATE sensor as I ordered from autoparrts way. Except auto parts way scratches off the vw logo
I replaced the sensor and also spun the wheel by hand while looking at the advanced measuring blocks in abs module to see the speed.
I am getting speed from th g46 sensor when I spin it by hand.
I then cleared the codes and went for a drive.
STILL getting the same codes popping up. I don’t know what to do now. Clearly the pick up ring on the wheel bearing is ok too since it’s picking up speed. Double checked wiring too.
Any suggestions. ?
Strider17
Update: fixed
Turned out to a bad wheel bearing pick up ring. It was missing a piece. I guess when I was heating up the seized bolts for brake carrier.
The speed was jumping up and down when driving and logging the sensor with vcds.
740GLE
NH
I'm kinda curious why you needed to heat up the carrier bolt.
24 hr soak with penetrating oil and a 24" breaker bar wasn't enough?
Were you able to return the VW dealer sensor?
roni024
Syracuse, NY
2015 Passat TDI SEL DSG
Strider17 - Thanks for keeping us in the loop til completion. Your experience may be valuable to others in the future.
Strider17
the carrier bolts are in the worst place possible in the rear. plus doing on the garage floor. penetrating fluid doesnt work if their are seized with corrosion and salt. give it a try one day haha :p
and yes i was able to return the sensor.
740GLE
NH
I was this close in having to replace rear rotors on our MK5 before it got back, I got out of it by just changing pads.
I'm thinking I will be doing it on our '15 passat soon as there is pretty good uneven pad deposits on them right now.
roni024
Syracuse, NY
If you have uneven wear on your pads, pay close attention to the rubber caliper piston boot. If it's not very pliable and fully/evenly compressing when the piston is pushed in it will cock the inner pad.
Strider17
for anyone taking taking off the carriers, get yourself the proper short stubby tripple square bit and a "bent" ratchet that looks like this:
https://public.snapon.com/R_RRD/Objects_lg/images/SBF80A.jpg
then put a extension on it (your cars oem breaker bar for lug nuts) and try and crack the bolts with one shot.
thats the ONLY way that works ...and ive tried it from every angle before
cheers
740GLE
NH
great idea, i do have the 20ish piece metalnerd branded kit from idparts, fingers crossed.
