Why would you want to do this? A 1.9L TDI would mean with an external VE pump (95-03) or internal injectors aka Pumpe Düse (04/06). Both have ECUs are fully customizable with a decent software provider (Malone). They can remove the immobilizer, EGR, MAF etc, and can accommodate any size turbo and nozzles that you would want to run. If you are looking for someone to make a stand-alone harness please visit http://www.fastforward.ca and I can do something like this and have it 100% custom for your application. Unless you are looking for something "fun" to do, there's no reason to go fully custom aftermarket ECU on these engines.Dear forum:
Does anyone know of an aftermarket standalone ECU for the VW TDI 1.9L engine. I wanted to use the engine in a Lotus 7 build.
thanks!!
Scott
If I can run a a VW ECU, then that would be the easiest way to go . The issue is that I won't need the clutch safety switch.Why would you want to do this? A 1.9L TDI would mean with an external VE pump (95-03) or internal injectors aka Pumpe Düse (04/06). Both have ECUs are fully customizable with a decent software provider (Malone). They can remove the immobilizer, EGR, MAF etc, and can accommodate any size turbo and nozzles that you would want to run. If you are looking for someone to make a stand-alone harness please visit http://www.fastforward.ca and I can do something like this and have it 100% custom for your application. Unless you are looking for something "fun" to do, there's no reason to go fully custom aftermarket ECU on these engines.
Clutch SwitchIf I can run a a VW ECU, then that would be the easiest way to go . The issue is that I won't need the clutch safety switch.
IF you would , please let me know if that is possible and who (Malone) is.
Many thanks!!
Scott
Along this vein, anyone running over 6300 RPMs on a stock ECU VE motor yet?
Decel map? This also interests me.Decel map is no problem. Diesel rpms drop like a rock when flatlined.
plenty of idi guys rev past that, they've got heavier 8mm valve stems, toogranted no tdi should be reving above 6K, you can but the taper off on the curve is drastic for so many reasons.
From what I understand though di diesels have trouble burning the fuel in the shorter time window available at high rpms when compared to idi's. Might just be complete bunk though.plenty of idi guys rev past that, they've got heavier 8mm valve stems, too
guys spinning 5500 on b series motors seem to run 40 deg or more of advance, so that certainly makes senseFrom what I understand though di diesels have trouble burning the fuel in the shorter time window available at high rpms when compared to idi's. Might just be complete bunk though.
why is your screen resolution so small in 2017? even at 1080p on a 29" monitor its not even taking up more than 5/8s the screen. No one has time or is willing any more to resize pictures for people with screens still displaying at 480p lol, get with the program!wth does your pic need to be so big ?! ^^
i'm browsing with a smartphone like many other people in 2017, why don't YOU get with the program? ... desktops are so 2009why is your screen resolution so small in 2017? even at 1080p on a 29" monitor its not even taking up more than 5/8s the screen. No one has time or is willing any more to resize pictures for people with screens still displaying at 480p lol, get with the program!
or a blender ... my house is pretty "dumb" ... not many connected devices aside from an ancient ps3 and my phone ... don't want my fridge or my ear hair trimmer spying on meUh.... 2017 and "IOT" would be browsing with your refrigerator...
BECAUSE THIS FORUM. its what 20? 30? years old? at least vwvortex updated there format and integration. this forum is like 1990 format and needs an overhaul. thats why i dont brows on my phone. im not addicted to it. rocking a galaxy 8btwi'm browsing with a smartphone like many other people in 2017, why don't YOU get with the program? ... desktops are so 2009
no no no no nothis forum is like 1990 format and needs an overhaul.
