Old November 30th, 2017, 06:39   #1
jdtdi
Fuel Economy: 38 mpg
Default 2005 Passat bad trans - what is it worth?
I have a 2005 Passat that was meticulously maintained. 2 weeks back the trans went and I do not want to put any more money into the car. It has 180,000 miles and the engine is good. It was meticulously maintained using only Pentosin II oil. I also added Opti-Lube XPD on EVERY fill up. The balance shaft upgrade was done at 50,000 miles and is still going strong. RAXLE axles were installed as well around 50,000 miles. A remanufactured torque converter was installed at 150,000 miles.
jdtdi is offline   Reply With Quote
Old November 30th, 2017, 07:24   #2
igiveup
Not sure about in the States, but up here you're lucky to get $1000 with a dead transmission. I've seen them go as low as $500.
igiveup is offline   Reply With Quote
Old November 30th, 2017, 07:53   #3
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Convert it to a manual.
Wagon or sedan?
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old November 30th, 2017, 08:57   #4
jdtdi
It is a Sedan. Do you know anyone in the New Jersey area that would convert it to a manual?
Old November 30th, 2017, 09:33   #5
Windex
Windex's Avatar
Dunno - best to check the eastern US forum.
Old November 30th, 2017, 10:23   #6
BleachedBora
BleachedBora's Avatar
I picked up a wagon last Friday with 182,000 on it, good engine and transmission, though the rest of it was a bit rough. Perfect swap car though.
He did a full cam and TB change with my parts and a balance shaft delete kit all in the last 10,000 miles. Mostly new alternator and starter.
...and I paid $300 for the entire car.
YMMV
BleachedBora is offline   Reply With Quote
Old November 30th, 2017, 12:54   #7
imo000
imo000's Avatar
Unfortunately unless you part it out, it's worth the same as what a junkyard would give to a non runner. Up here that's around $300.
imo000 is offline   Reply With Quote
Old November 30th, 2017, 14:52   #8
afarfalla
afarfalla's Avatar
where are you in Jersey
afarfalla is offline   Reply With Quote
Old December 1st, 2017, 07:01   #9
jdtdi
I live near Asbury Park, down the shore.
Old December 1st, 2017, 09:10   #10
d0u8l3m
d0u8l3m's Avatar
TDI(s): B5.5 Passat
I have a cheap trans in connecticut if you wanna get it running for a better sale. Could probably still get 2-3k if its running imo.
d0u8l3m is online now   Reply With Quote
Old December 1st, 2017, 10:03   #11
afarfalla
afarfalla's Avatar
My brother is in Bordentown, PM me your phone number I'll have him stop by and take a look at it, he travels the Shore weekly.
Old December 1st, 2017, 17:41   #12
Uberhare
Uberhare's Avatar
Fuel Economy: Depends on what I'm towing!
Sedans only make good parts cars IMO
2005 Passat BHW Variant w/01E 6 gang
"Pilots - looking down on the world since 1903!"
Uberhare is offline   Reply With Quote
Old December 4th, 2017, 12:19   #13
imo000
imo000's Avatar
The trunk has more room that it looks. Carried all the necessary go karting equipment for 2 years for my son and this also included a set of rain tires too and everything one needs to race a kart for a season. Yes a wagon would have been better but this sedan sort of fell in my lap a few years ago with a bad transmission.
Old December 6th, 2017, 23:18   #14
wtribeflyer
Sedans rock!
wtribeflyer is offline   Reply With Quote
Old December 9th, 2017, 09:10   #15
Smokerr
Fuel Economy: 43.5/32/28
But wagons just haul.
2005 Passat TDI Wagon
Smokerr is offline   Reply With Quote
2005/TDI JettaWagon/Bad Trans/ CharlotteNC DukeMatisse TDI Cars for Sale/Wanted 5 September 12th, 2015 16:45
2005 Passat Wagon in Fort Worth mtbr297 TDI Cars for Sale/Wanted 27 May 21st, 2011 19:22
2005 Volkswagen Passat, broken timing belt - $4700 is it worth it? nubz69 TDI 101 18 August 16th, 2010 07:51
2005 TDI Passat for $16,500 - is it worth it? MD_TDI_FAN TDI 101 28 October 11th, 2007 13:40
2005 Bad Trans Already??? RocketPassat VW B5 Passat TDIs 12 February 3rd, 2006 18:37
Page generated in 0.14441 seconds with 12 queries
[Output: 121.92 Kb. compressed to 100.89 Kb. by saving 21.03 Kb. (17.25%)]
