PeterUpNorth
After an extended trip noticed my left rear wheel was getting hot. Assumed it might be bearing, so replaced both of them....apparently just for the experience!!!
After putting the brake caliper back on I noticed the wheel won't hardly turn by hand. So loosened the piston back, it spun fine. Took it for a test run and again the wheel is hot. Seems once the brakes are applied a few times the piston/pressure won't back off. (just the one side)
Is this a caliper gone bad, or could it be something else?
2001 Jetta, 200,000 km.
