SummerSmoke
Hi! I'm very new at this so sorry for what must be a frequent topic around here.
My 2002 Jetta (165k miles) cranks but will not start. It cranks somewhat slowly, around 125 RPMs but I'm not sure if this is slow enough to indicate a problem. I've tried going through several guides but I'm struggling on how to narrow it down from all of the possible issues.
Possibly related symptoms: mild electrical sound with key turned before ignition (possibly normal for glow plugs). During cranking overhead dome lights dim and flicker. This has always been the case and I thought it was normal but perhaps it is related. After the engine stops turning, there is an electrical sounding BZZZZZZZT for a few seconds. I think this is the starter motor, not sure if that's a normal noise or not. Car has always had trouble starting in cold, and failed to start in extreme cold weather once though this was possibly a result of fuel gelling.
Of note also, the last time the car ran it was refueled. Could indicate a bad batch of fuel???
Here are the hypotheses I've come up with:
Bad battery: unlikely, battery is less than 1 month old. Checked by O'reilly, rated as good. Voltage normally reads about 12.75v, drops to 10.9v while the engine is turning over. Seems normal to me, but I could be wrong.
Bad starter motor: possible, matches symptoms as described by people who had this problem before of low crank RPMs, trouble starting in the cold, and flickering dome light. I tested the voltage between the two electrodes on the solenoid and it seems to be getting good voltage so I don't think it's a connection issue. How do I determine if the motor itself is the problem (aside from replacing it)?
Lack of fuel supply to the engine: lots of possible problems here. How do I know if it's a fuel problem, and if it is how do I narrow it down? Timing suggests it could be a fuel problem. It's about time to change the fuel filter so I ordered the materials and I'll see if that helps but I have no idea if that's the problem. Also, several people have mentioned checking the clear plastic tube between the filter and the fuel intake pump for bubbles, but in my car this tube is black for some reason—perhaps it was replaced at some point? Not sure how to check if there's air in the line without the clear tube.
Lack of air supply to the engine: same issue as with fuel. How do I know if the problem is one of air supply and if so how do I narrow it down from there? Anti-shutter valve tested and seems to be working fine. Similarly the engine air filter is due for a change, so I'm gonna do this but the filter doesn't look super dirty so I doubt that's the problem.
I also checked the fuel shut off wire voltage. It was around 11.5v which seems a little low but not low enough to cause a problem???
Timing belt looks to be in good shape, not sure how to tell if it has slipped but it's pretty tight so that doesn't seem real likely.
Any hunches or tests to run would be really helpful. My dad is sending me a PELA pump I accidentally left at his house, which hopefully I will be able to use to diagnose fuel blockages but it won't be here for a few days. So until that gets here I'm sort of out of ideas of things to check.
Thanks for reading this wall of text!
