I have this posted over at VWVortex as well, but I have read much of my 09a transmission information from over here, so I figured maybe you guys could have some useful insight.
I have been experiencing all kinds of fun transmission problems with my 2002 Jetta equipped with the 5-speed tiptronic transmission.
I originally threw a code for P0722: Vehicle Speed Sensor, no signal. No speedometer reading up until about 10-12 mph and no 5th gear. Removed transmission, replaced all three speed sensors in the inside of the transmission. Reassembled and tried it out.
From there, I was still receiving the previous code with no improvements. Only possible issue from there I thought was the transmission control module. Today, I received a remanufactured transmission control module with the revised part number (09A927750T to 09A927750AJ).
I thought I may have had to have the TCM reprogrammed/flashed, but that is apparently not the case.
I then experienced two new codes: P0501: Vehicle Speed Sensor, performance range and P2637: Torque Management signal.
I cleared the codes and tried driving it again, but still to no avail. These codes have yet to return and no CEL has lit up, but I have a P0722 code stored again.
It was suggested I check the harness between the transmission and the TCM now, so I will be checking that tomorrow as well.
I have checked the grounds from chassis to transmission as well. All 9 sensors and solenoids were replaced shortly (2 weeks) before I began experiencing VSS problems. The transmission pin-out ohmed out fine.
Any input is much appreciated. Thanks guys.
