Clicking is perfectly normal. That means the N75 is working. The N75 is probably working, but is sticking internally. That's why I suggested taking it out, and spraying the WD40 in there. If you put it back in and your problems are gone, then the N75 was getting stuck (not an uncommon problem) and you might want to look into getting a new one.
As for the previous question about the Dawes, technically, yes, it is supposed to help with boost control, but not this problem. The Dawes basically is to control overshoot more than anything. This person's problem was boost surge...meaning full/partial boost cycled over and over again. The Dawes takes a car peaking at a high psi (over 20) which settles down to 15 psi, and converts it to a car which peaks at about 18 psi (or whatever you set it to) and settling to 16 or 17. Meaning you get a more constant boost pressure, and this is also easier on your turbo itself, so longer turbo life.
