ilikepie911
Hi everyone and thanks in advance for any help offered.
I've been searching through this forum and google for any reason as to why this is happening
Issue:
When I start the car after more then 5 hours (seems when engine temp drops below 50 degrees)
- Engine idle is rough and fluctuates between 750 and 900 rpm
- Everytime it drops the headlights get dimmer/brighter
- When I try to take off, the engine bucks like a horse and I have to force the revs over 2200 until the bucking becomes unnoticeable (feels like misfire?)
- All cabin lights flicker as if I'm at a rave
- Radio randomly cuts out (aftermarket)
- Randomly car will beep at me and handbrake light and abs light will come on for 1 second. (usually occurs 1-2 times)
- No Error codes are thrown
- Once temp meter hits 50 engine runs normal and all lights stop flickering
Things I've done
- Someone here suggested cleaning the ground contacts, I cleaned the positive contacts on the alt and grounds under the battery
- Checked connectivity with voltmeter of positive on alt to positive on bat terminal, and connectivity of ground on bat to alternator and engine block and body. All seems good
- Replaced Alternator (as it was not charging past 13, now charges at 13.8 under load)
- Replaced fuel filter and ran Ligui molly Diesel injector cleaner.
Please note I only have the standard OBD2 tool and not a VCDS
Any suggestions would be greatly appreciated.
Issue:
Things I've done
