Steve, just like you can never have enough air flowing through the intake
- sorry couldn't resist
About the gauges. . . I got thinking last night driving home - Boost,
do we really NEED that guage? EGT, oil temp, maybe oil pressure . . .
Boost is ECU limited regardless of the engine design as long as the engine can reliably determine boost, ie don't even think about messing with where the IAT/MAF is plugged in. It'll show you stuff but it won't tell you if the engine is gonna blow unless you have modified the engine to the point where the computer doesn't know what is going on. By the time you see the boost on the gauge - too late.
Sure the gauge is pretty damn cool to watch and all that - but it doesn't give you anything more than Vag-Com can give you, although it does give it to you all the time - but . . . conditions aren't gonna change much and if you don't have a vag-com, money invested in making your own or buying Uwe's is much better spend than on a boost gauge.
Oil Temp, that is something you can't get off of the computer and something that should be monitored that can't be other wise.
EGTs - very important if you have more than one mod. Critical almost. esp now that I have seen heat deformation on an inconel turbine out of a TDI . . . .
Heck Cylinder head temp probably is more improtant than Boost.
What it comes down to though:
What do YOU want?
And What do you NEED?
