Turbo_Diesel_Man
I have a 2001 jetta TDI. the problem is my windows will not work from the drivers side. windows will work from each window just not from the drivers seat. However if I disconnect my battery or disconnect the harness to my window regulator on the driver door and plug it back only my driver window will then roll down but only for a few secs. and then it wont work again. I have put a new driver side window switch on, new door harness on, new window motor on, new door lock actuator on driver door, checked ALL fuses, and bought new CCM. I don't think I bought the right CCM though because when I install new CCM the alarm sounds as soon as I plug in the harness?
The sunroof works but the doors locks from the drivers side will only lock and unlock the drivers side
Also if the car sits for a couple days the battery is drained and I have to charge the battery. but as long as I drive it daily the battery stays charged. I have tried disconnecting the pos. and neg. battery terminals and holding them together for couple min. and re-installing them on the battery. I have ran a vcds got the following:
16786 - EGR system excessive flow
16764 - glow plug/heater malfunction
19561 - valve for intake manifold flap open or short to grnd
00668 - ABS supply voltage terminal 30
00953 - interior light time limit
01334 - door control module: rear right
01333 - door control module: rear left
01332 - door control module: pass. side
01331 - door control module: driver side
any help would be greatly appreciated
