Depends on what mods you have. The TacoTaco intercooler is what I have also. If you are already highly modded, a fmic would be a better option. If you're stock and are only going for a mildly upgraded car, the TacoTaco intercooler can't be beat for the price.
If you do go the TacoTaco smic route, you may need to modify a few things. I rigged up rubber spacers to go on the mounts for the intercooler using parts at Lowe's Hardware. Let me know if you want more info on that. The other thing is another map sensor for your intercooler. That intercooler takes the smaller map sensor. What I did was buy a BEW map sensor and it worked perfectly. Good luck on whatever you decide to do!
