little bit stuck maybe you guys can give me some help
in the process of swapping the warped china head from the Ahu and using a 1z engine from a Passat as donor
Can we use the 1z head complete, intake manifold exhaust manifold turbo etc? I noticed right away the EGR cooler on the intake being different
not seeing any thing else different enough to stop me from using the none EGR head complete
if we use the none EGR head, What do we do with the coolant hose's that would other wise go to the cooler?
or is it better just to swap the AHU intake/exhaust/turbo over
