SEABEECM1
i have looked and i cant find a "how to" on removal and install of a lower control arm - is it easy as removing a couple of bolts and the ball joint mounting nut?
Get this tool (free rent). Bushing go in like butter. You will thank me later. Harbor freight also sells it.SEABEECM1 said:i have looked and i cant find a "how to" on removal and install of a lower control arm - is it easy as removing a couple of bolts and the ball joint mounting nut?
