So today, I finally dove into the front suspension. I bought a set of ST coil overs last year and needed to get them on. Passenger side was easy. Driver side gave me some difficulty. Couldn't get the axle to come out of the hub. Then it seemed to separate from the inside (trans) and gave me enough slack to get the knuckle off the lower control arm and drop it down low enough to pull it off the strut. Great... So I thought.
Upon reassembly, everything seemed to go back together just fine. Took it out for a drive ad I felt a horrible clunk clunk clunk. W t f? I re-checked all my bolts and everything looked good.
Still there. I basically disassembled everything and redid it all just to make sure things were seated. Yep.
Still there... Clunk clunk clunk. W t f?
Re-installed the original suspension thinking maybe my ST stuff was the culprit. Nope still there. W t f?
It felt like a wheel was not bolted down. Hmmmm... Can't tell where it's coming from.So I jack up the front end, pull the wheels, and run it in gear. This is what I found!
This is the driver-side axle. I tried pulling it out and seeing if there was something off, but everything "feels" fine. You can clearly see the wobble.
What gives? Anyone encounter this? Do I have a broken cv joint?
http://www.youtube.com/watch?v=F_rFrAy4Wp4
