blu_jet_92
Title says it all. I bought .216's and just stuck them in....? was that the wrong thing to do??
Well, this will probably open a can of wurms ...... but, lets start with where you bought these nozzles from. It they are ebay/chinese then it doesn't matter, they need replaced. If they are from a reputable supplier (and the assumption then is that you disassembled the injectors and installed the nozzles yourself --- I think Kerma has a howto with pictures floating around somewhere on this) then you need to get out your VCDS, login cick engine/adaption/13 to see whether the readings are within +-2 of each other (you will see 3 readings in this block, injector #3 is the baseline measurement and what reads as #3 block is actually #4 block.) If they are within this range they are probably fine.Title says it all. I bought .216's and just stuck them in....? was that the wrong thing to do??
