There are some factors more fundamental to proposing any new method of combustion/heat release that you have missed.
Recall from Heywood that:
BMEP = IMEP_gross - TFMEP
where TFMEP = total friction MEP = PMEP + RFMEP + AMEP
where RFMEP = rubbing friction MEP
and AMEP = accessory MEP
I can get a high BMEP for a given gross IMEP because I can significantly reduce the PMEP (other parameters are largely unchanged). My simulations have shown that the turbo setup I have realized gives a very beneficial IMP/EMP ratio compared to other setups.
If we consider some of the builds that have been documented here, we are seeing torque values approaching 380 lb.ft. This equates to a BMEP of 34.4 bar, which is reached on largely stock bottom-end (i.e. stock compression ratios) 1.9 TDIs. My simulations suggest that on these builds the pumping alone contributes to over negative 3-4 bar MEP, and PCPs peak well north of 250 bar. I have shown PMEP in my "Insane..." thread to be very small and in fact positive in certain operating points. I can get IMP/EMP ratios of about 1.3, i.e., if my boost pressure is 4 bar (absolute), my EMP is in the order of 3.1 (absolute).
At the rated power point that would give 450 HP @ 5500 RPM, my BMEP is right around the 36.6 bar mark. But I'm reducing my compression ratio to a value anywhere between 15-16:1 compared to the builds that are keeping an unchanged CR from stock.
As long as I don't see any significant transient boost/EMP spikes, PCP will be the least of my concerns, but rather the heat flux that will be going through the pistons, cylinder heat and exhaust ports.
The injection strategy at full-load, high-RPM operation -- regardless whether common-rail or not -- typically reverts to single injection. Multiple injections per cycle are not done as a rule at these operating points.
EGT is mitigated by a combination of maintaining a relatively lean equivalence ratio, effective charge cooling, low EMP, near-MBT injection timing and non-extended injection duration. An EGT plot is posted in the other-referenced thread. It is not expected that this engine will be subjected to sustained EGT levels exceeding 850°C, so short bursts into 900°C territory will not cause undue problems.
