SlowMotionReplay
This is all in regards to a 2006 Jetta Sedan TDI, 5 speed manual.
I've got an oil leak somewhere on the back of my engine, but I can't tell exactly where it's coming from. The back of the engine block was completely coated with oil, all the way from the oil pan, up to as high as I could see from below. There was also a significant amount of splatter on nearby hoses. The lower hoses had a better coating than higher up hoses.
I did an oil change on Wednesday in the evening, and now 1 day later there doesn't appear to have been any significant oil loss.
I've wiped everything down and will try to take another look on Friday to see if I can tell where the oil is coming from.
Does anyone have any ideas what might be leaking, or what I should look for?
