A while back I'd posted here that my TMPS warning had come on in my 2010 Jedda TDI when the temperatures started dropping below 40 degrees locally. The pressures when cold still showed 35 PSI. Over time I've been adding about one PSI at a time to see at what point the system would think I had enough pressure in these colder temperatures. It appears that 39 PSI does the trick under current conditions (lows a bit below freezing, highs averaging the high 40s/lower 50s F).
After upping the tires from 38 to 39 PSI, it was on my sixth drive (the previous five all being rounds of my 7 mile, 15-20 minute one-way commute) that the pressure warning finally finally stopped coming on. FYI, I've been setting the pressures using a high-quality dial gauge, not relying on the (highly variable) readings you get from the gauges built into service station air compressors. So it certainly can take a while for the system to shut off the warning.
A friend who also has a 2010 just took his car into the dealer for its 10k service. When he mentioned the TPMS warnings (his had come on at the same time as mine) the dealer's solution was to turn off the warnings altogether. I suspect I'll be using a different dealer for servicing
