Old March 12th, 2015, 10:56   #1
dr_bartolo
Default big smoke puff and "awful" non-diesel smell on startup
Hey all. More fun with Wifey's blue 2000 beetle. She just took off from the studio and reported a "huge" puff of "possibly brownish" smoke and a really bad smell on starting up. Also said it might have been kind of "hopping" a little at the stoplight when she was coming in.
The only existing issue I know about right now is a little radiator leak.
Anybody have any insight on the weird smelly startup?
dr_bartolo is offline   Reply With Quote
Old March 12th, 2015, 11:55   #2
Dimitri16V
Dimitri16V's Avatar
no offense , but lately we get a lot of those posts
members here have no telepathic abilities
check with wife and look at the car , first
anything else is just specualtion
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Old March 12th, 2015, 20:19   #3
98VWTDI
TDI(s): 98 Jetta
Fuel Economy: 52 mpg hwy-39mpg city
As Dimitri16V said would need more info, black smoke would be running rich (not enough air), if your smoke is more brown / white like unburnt raw fuel, like it's injected at the wrong time. Check the intake for carbon restriction as well, since that is a common issue.
98VWTDI is offline   Reply With Quote
Old March 13th, 2015, 02:48   #4
wrenchman30
Fuel Economy: 43 best befor egr much better now
its car smoke signals letting all the other cars on the road know your wife is on the road and to get out of the way, brownish is a indication the wife is in a foul mood and that hubby is going to catch hell soon when wife gets home with sore feet from walking and having to show boobs to tow truck driver to get a reasonably priced tow home, on a serious note I would think it was blowing out coolant on a start up
wrenchman30 is offline   Reply With Quote
Old March 13th, 2015, 08:29   #5
Powder Hound
Powder Hound's Avatar
Depending on how many miles on the car, how long it has been sitting since last running, the color and smell of the smoke, and how quickly the smoke clears up, the problem could be anything from timing problems, oozing coolant past a barely failed head gasket, to oil oozing past valve stem seals while sitting.
As the ALH cars age, and miles pile up, they are exhibiting age related problems such as wire harness failures at door and trunk/hatch bending points and engines that are showing signs of age like smoky startups.
Like Dimitri says, direct observation and as much information as possible will be very helpful in determining the proper resolution.
Cheers!
PH
Another Puff of smoke at Startup thread flashmayo VW MKIV-A4 TDIs (VE and PD) 2 June 11th, 2014 06:12
Puff of smoke at startup REDNECKDZL Ontario 10 March 30th, 2009 15:00
Diesel "smell" and lower mpg with new fuel filter y2khardtop VW MKV-A5 Golf/Jettas 27 November 21st, 2008 18:42
2006 tdi jetta puff of smoke on startup tammons TDI Fuel Economy 8 January 21st, 2007 22:54
puff blue smoke / cold startup ingrahamm TDI 101 8 October 17th, 2003 14:31
Page generated in 0.12076 seconds with 11 queries
[Output: 68.77 Kb. compressed to 60.94 Kb. by saving 7.83 Kb. (11.39%)]
