Old December 13th, 2012, 05:07   #1
01TDINAZ
Default 01 Jetta TDI Power Loss, Loud Engine
Started to head to work this morning, got a block from home and the engine got real loud and lost power. Not a complete shutdown, just low power. It came out of nowhere, never done this before. I just turned around and got it back in the garage, didn't want to drive it in this condition. Any ideas, or anyone near Chandler, Az that could give me some direction on this?
01TDINAZ is offline   Reply With Quote
Old December 13th, 2012, 05:11   #2
PDJetta
PDJetta's Avatar
Perhaps one of the EGR pipes to/from the EGR cooler broke, causing loss of exhaust pressure to operate the turbocharger, causing a low boost issue. Or an intake pipe piopped loose. If either, it is relatively minor.
Nate
Old December 13th, 2012, 05:33   #3
01TDINAZ
Thanks for the reply. Just checked and those parts look fine, no signs of any problems. My first thought was an IC boot, as those have blown off/broken on my truck and are very loud. But that's all intact...Still searching
2001 Jetta TDI, 5 speed, Stock. 170k and counting..
HELP: HUGE pothole caused massive vibration, loud engine noise, & loss of power TDI_Lee VW MKIV-A4 TDIs (VE and PD) 11 December 22nd, 2014 01:03
A4 Jetta loud engine rattle, power loss, smoke theaussiepea VW MKIV-A4 TDIs (VE and PD) 6 February 12th, 2010 20:01
Loss of power 01 Jetta TDI, not limp mode. HELP wakdady TDI 101 6 June 13th, 2008 18:34
Loss of power '01 jetta tdi JettaTDI777 TDI 101 2 August 24th, 2004 22:30
01 jetta tdi power loss ? tdiman VW MKIV-A4 TDIs (VE and PD) 2 September 9th, 2002 08:29
Page generated in 0.14984 seconds with 11 queries
[Output: 57.94 Kb. compressed to 52.38 Kb. by saving 5.56 Kb. (9.59%)]
