copilot
Issue appeared after install of Ziza LED light kit from ECS. Resolution was replacement of fuse in slot 6 which I apparently toasted when installing the bulbs. Tracking this issue down using the subject code and bulb out indicator was kind of beastly so I thought I'd record the resolution.
The Ziza kit is awesome except the reading light surround is pretty janky with the larger LED bulbs. I'll have to shave mine a little to make it around the new bulbs.
Who at VW thought it would be a good idea to tie the interior lights in with the tail lights? Not having interior lights at night is inconvenient but at least I can make it home without getting a ticket.
Thanks to MiksTDI for resolving the issue, especially since it got dark while I was there and would have surely been pulled over without working tails.
