tryin2vw
Thanks. A couple of companies that advertise VW Cluster repair for immobilizer issues have been contacted to see what it would cost, both $ and time. Does anyone have experience with somebody.Went out and measured the coil on the spare lock cylinder I have, got 22.3ohms so it sounds like your coil is ok if you're getting that reading all the way to the cluster connector.
Yes you can reuse your same keys if you change your cluster. You will need the SCK of your original cluster along with the SCK of the new cluster to adapt the cluster to the car, then the keys to the new cluster.
One local guy suggests an immobilizer delete, but the dash light stays on, so not really a fan of that suggestion.
