Maverick80
I just picked up an mk4 Jetta with a 1.9 ALH , I need to Change the oil but all other maintenance is good and I’m about to delete the egr so where should I start as for as bumping up power??
pp764s improved mine over the stock .185sA set of .205 nozzles will improve your performance quite a bit and not kill your FE.
11mm pump is no needed before 300hp on ALH. Lift pump is no needed before 250hp if everything is fine on original line, helps to get rid from air though on first starts or filter changes. Sometimes there are problems on original line, and it needs bit tweaking even before tuning to work as it should.Once you have a vnt17 or larger, an 11mm pump + lift pump would help and give you fueling for around 200
200-225hp you better open that wallet up to get that far with an ALH. I was around 180whp in my old Jetta and was into it over 3k just for that.
welding is dirt simpleWell p0wer you are right but what’s the odds the OP can do that?
That’s true. I’ve been welding since I was 16 and self taught. Some people are just afraid to do it though.welding is dirt simple
like seriously, a five year old could learn to do it with the help of a few youtube videos
What budget do you have, how much can you make yourself and what power levels you are really aiming?I just picked up an mk4 Jetta with a 1.9 ALH , I need to Change the oil but all other maintenance is good and I’m about to delete the egr so where should I start as for as bumping up power??
I won´t take side for anyone personally Everyone doesn´t have that much passion for building, that they want to get all tools or even proper carage. If so, then every individual project will be much more expensive when everything must be purchased ready, even installation. Every people have so many different styles.
This is why its almost impossible to answer question "how much does it cost to tune 90hp to 300hp", and that´s why there are simple and universal options for moderate results with comparatively high price, such as "stage x-tunes", exhausts, ic kits with installation service and so on. But would it be profitable or will it be tuning or is it self built? Well, everyone decides for themselves.
Because im poor and i want good results and durability for the currency, there isn´t much options
