McGuillicuddy
Sorry I know this has been asked again and again, but to be fair there do seem to be some newer "quiet" clutch options out there that don't show up much in my searching. I know the South Bend Stage 2 clutches will hold a Malone Stage 2 ALH (with nozzles) but pretty much everything else seems hit or miss or borderline.
Sachs VR6/G60: rated for 300ft-lbs but the forums are filled with stories of this clutch failing prematurely under much less than that. Plus it is a known rattler.
Luk 17-050: no official rating but it seems to hold good power for some people.. IDParts estimates 260 ft-lbs which puts it on the hairy edge. Attractive because of price. DMF a bit off-putting.
Sachs Quiet Clutch: Rated for 275ft-lbs which means it should hold but only about 10% margin. If you get a "weak" one you could slip it.
IDParts Quiet Clutch: no official stats but presumably same as Sachs Quiet Clutch.
Valeo VR6/G60: 230 ft-lbs. No stronger than stock apparently.
Anything I'm missing, or wrong about?
