dillenger1
can the automatic window be added with vcds?i think i read somewhere that only the passat got it factory.when i go into my settings .the only thing i have under the open close menu, is door locking
I assume you also coded the mirrors to dip in reverse? If so, can you code them both to dip simultaneously?As an example, I have power folding mirrors installed and have them set to fold/unfold with lock/unlock. The folding mirrors required upgraded door control modules. Still had to activate the convenience features and enable the menus in car settings to control them.
To enable for Group 42 (Driver's mirror) its the same procedure as you did for Group 52. Once its set up, I'm just curious if you can only dip one side at a time using the select switch or whether there's a way to set it up for simultaneous dipping (sounds like a dance move!).I do have the passenger mirror set to dip in reverse, for parallel parking. I don't remember if the option was there for the driver side or not. I'll try to check sometime this weekend.
I have this tweak done, and yes mine does return to the position I had it in last (2015 GSW SE). After backing into a spot it will only return once I have turned the engine off. Or if I start to drive away. It is not instant once you pull the car out of park.Cuzoe, could you confirm that you have correct memory operation on your passenger side dip, i.e., that the mirror returns to its exact previous position when out of reverse?
yes it doesYou can code it in if you have the the KESSY system. Does your car have push button start?
