Old February 15th, 2019, 12:35   #1
kennster
Default Bottoming out problem
I just purchased a 2015 Passat TDI...loving it...but it seems to bottom out in the front...but the shocks seem fine..Im guessing the Passat is a softer ride than my 2011 Jetta TDI...but it seems too mushy....anyone else have this issue???
2002 Silver Jetta TDI with over 468,000 kms..TECHNINE STAGE 2 CHIP...SPRINT 764'S..TDIHEATER...Ventectomy....Boost Gauge..Boost Valve (RIP)
2011 Black Jetta TDI Highline 240,000 kms..(RIP)
2015 Black Passat TDI Highline 95,000 kms
Other vehicle is a 2004 F150 SVT Lightning 405RWHP 504RWTQ
kennster is offline   Reply With Quote
Old February 15th, 2019, 16:02   #2
Strider17
the diesels do have softer springs..
i put rear towing springs in mine and it lifted up the back end a bit..but id still like to stiffen up the front
Strider17 is offline   Reply With Quote
Old February 15th, 2019, 18:04   #3
kennster
Thanks Strider...i have two seadoos...was planning on putting on a trailer hitch...total weight is 1500lbs...do i need new springs on the rear??..
Old February 15th, 2019, 19:58   #4
Strider17
100% you will....with the stock springs i put my thule bike carrier and 2 bikes and the rear end was significantly lower..with just me in the car.
these are the ones i have:
https://germanoem.ca/parts/suspensio...115ct-sup.html
Old February 17th, 2019, 17:29   #5
kennster
Thanks Strider...cheersss
Old February 20th, 2019, 14:26   #6
Radek
It says these springs are for mk5/6 wagon, is it the same size as 15 Passat ?
Sent from my SM-G935U using Tapatalk
Radek is offline   Reply With Quote
Old February 21st, 2019, 05:30   #7
740GLE
Passat has a mk5 rear suspension so yeah they fit. Toss a mk5 rear sway bar on it too if you want to enjoy corners some more.
Passat went on a huge diet for the NMS vs the euro based B6. Comparing the curb weight of a NMS and a Mk5 jetta, the NMS is only a couple hundred pounds heavier yet has nearly twice the interior size.
740GLE is online now   Reply With Quote
Old February 21st, 2019, 05:36   #8
Radek
I was comparing GSW of the same year and was surprised to see a small weight difference, expected a lot more, which sway bar do you recommend and if there's anything for the front to help with cornering ?
Old February 25th, 2019, 14:43   #9
kennster
I went to a spring place...they said that they could change all the struts to bilsteins..they are firmer than stock...that would help the bottoming out...good idea?...or should i change the springs as well??
Old February 26th, 2019, 04:31   #10
roni024
New springs would help prolong the life of your new struts. It would be a wise investment.
roni024 is offline   Reply With Quote
Old February 27th, 2019, 08:45   #11
740GLE
It just shows you how much weight/bloat they cut out of the NMS!
GSW isn't the same rear end, its a mk7 on the MQB platform, GSW TDIs have twist beam, not IRS.
MK5 and Mk6 rear ends are pretty much identical seeing MK6 JSW (up until 2014) was just a warmed over mk5.
I went with H&R for their maintenance free quiet bushings, haven't had any issues in the 2 years it's been on.
Had the same bar on my MK5 for 120K and it was silent.
Old February 28th, 2019, 14:18   #12
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
I think the shocks and struts play just as big of a role in bottoming out as the springs do.
While the springs support the weight of the car and a fatigued spring can allow the weight to push down more, the struts and shocks have valves inside which are supposed to dampen quick or heavy movements.
In this case, since the car is a 2015 I highly doubt the springs are that fatigued already. I bet the OP would see a greater difference with swapping out the shocks and struts.
I personally recommend the Koni Special Active (previously called FSD). I have them on my car with the stock springs and the car rides SO MUCH BETTER.
Fixmy59bug is offline   Reply With Quote
Old March 10th, 2019, 10:35   #13
kennster
I replaced the shocks and struts with Bilsteins....The ride is soooooo much better...it feels like my old jetta now.firm and can feel the road....not like a cadillac elderado like it used too.....thanks guys..cheers
Old March 10th, 2019, 11:06   #14
Radek
Is there any way to stiffen up the rear on a passat for towing beside new springs ? I only have 25K miles and would like to avoid it if possible, looking to grab 24mm sway bar for better handling at the same time
Old March 10th, 2019, 20:00   #15
kennster
I want the same thing..i have seadoos..gonna install a trailer hitch soon..i need to stiffen up the rear...
Question about bottoming out TDIEnthusiast VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 1 September 29th, 2015 07:39
rear supension bottoming out walshjo VW MKV-A5 Golf/Jettas 1 March 22nd, 2010 15:29
Bottoming out too much.... vegandavid VW MKIII-A3/B4 TDIs 5 September 9th, 2009 14:12
Rear Suspension bottoming out tdicolby VW MKIV-A4 TDIs (VE and PD) 21 September 17th, 2007 08:22
Bottoming out in my Beetle holly TDI 101 8 January 27th, 2005 05:24
Page generated in 0.14744 seconds with 11 queries
[Output: 122.29 Kb. compressed to 101.67 Kb. by saving 20.61 Kb. (16.85%)]
