Old September 14th, 2018, 04:16   #1
tbones
Default How do I get a lock cylinder out of a B4 door lock with no key
Hi gang,
I got a nice condition original front door handle with intact wire.
The downside is, it has no key, so I'm trying to get the old lock cylinder out without wrecking the handle.
Has anybody been able to do this before? If so please enlighten meas to how you accomplish this feat.
Thanks,
Steve
tbones is offline   Reply With Quote
Old September 14th, 2018, 06:19   #2
0die
not sure but can you remove the clip or whatever is holding the back of the cylinder in place? without l having it in my hand I can't recall exactly how the back is...
I'm assuming you have already removed the handle from the door and it's on the work bench...
1996 Passat wagon TDI
assorted gas powered crap and motorcycles
RIP...countless Mercedes, Isuzu and other random diesels
0die is offline   Reply With Quote
Old September 14th, 2018, 08:02   #3
Abacus
That helpful B4 guy
Abacus's Avatar
I’ve done it and posted s how-to on here awhile back. I’m on my phone now so I’m not going to report or try to find it but you might if you do a search.
'97 B4: 453,000 miles Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
BUG*PWR 2013 Award Winner
Old September 14th, 2018, 09:58   #4
tbones
yes, it's out of the door, and on the bench... i have the circlip off, and the other pieces/springs off the back end of it... but, on my old (non-functional) handle with my key, you need to turn the cylinder (with key in it) 180 to get it removed...(hence, my predicament with the good handle with no key)
Old September 14th, 2018, 14:45   #5
lisab4
lisab4's Avatar
I have never been able to remove a cylinder with no key without braking the small pin inside
1996 Passat B4 1.9TDI 1Z
lisab4 is offline   Reply With Quote
Old September 14th, 2018, 16:05   #6
Abacus
That helpful B4 guy
Abacus's Avatar
I found the post
Old September 14th, 2018, 22:57   #7
Steve Addy
TDI(s): 97 Mk3
If you have any spare VW keys try them. Heck even try the current ignition key, you might be surprised.
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
the magic triangle spins in the peanut and then apex seals come out
Steve Addy is offline   Reply With Quote
Old September 17th, 2018, 06:56   #8
0die
is there anyway you can drill out the old tumbler? since you are going to use your keyed tumbler there is no real need to save the keyless tumbler (other than to salvage the pins and such)
Old September 25th, 2018, 07:07   #9
k9mattk
I've been able to pick my B4 lock with a pretty primitive pick set. Or sure a locksmith can for cheap.
k9mattk is offline   Reply With Quote
How to clean and re-key your B4 door lock Abacus VW MKIII-A3/B4 TDIs 23 October 23rd, 2018 03:04
Replacing door handle(B4) with used, how to remove lock cylinder without key dieselherb1 VW MKIII-A3/B4 TDIs 3 October 22nd, 2018 07:05
Wanted Passat B4 drivers door lock with key vixentd Private TDI Items for Sale/Wanted 0 January 16th, 2018 17:44
Key Lock Cylinder - Broken Hobhancock TDI 101 2 April 11th, 2013 19:52
Key Won't Go All The Way In and Lock Cylinder Loose - New Key Matching LandoCommando TDI 101 2 November 5th, 2012 14:39
Page generated in 0.14451 seconds with 11 queries
[Output: 90.12 Kb. compressed to 77.03 Kb. by saving 13.09 Kb. (14.53%)]
