Old June 26th, 2018, 06:48   #1
r90sKirk
r90sKirk's Avatar
Default 13/14 Fixed Passats - ANY ISSUES?
Planning to cash our 13 SE in (buyback), and pick up another 13/14 (lower mileage and SEL). Just curious if anyone has had any post modification issues with their "fixed" 13 or 14 (DSG trans)?
I have only read about the issues associated with the tried to fix MANUAL trans Passat's.
thanks,
Kirk
Honest TDI Enthusiast Performing Competent TDI Work
Currently Owning: 2006 Jetta TDI Laser Blue 269k, 2015 GSW (6MT) Pure White 78k, 1977 BMW R100RS 166k Silver Ice,
Gone, but not forgotten: 2013 Passat TDI SE 151k Opera Red, 2002 Jetta TDI Cool White 248k, 2000 Golf TDI 461k Bright Green, 1997 Jetta TDI Green 290k, 1996 Passat B4V Indian Red Pearl 337k
r90sKirk is offline   Reply With Quote
Old June 26th, 2018, 07:33   #2
LubeITMan
Hey Iíve got a 2012 SEL TDI with DSG. Got the emissions fix done about 6 months ago or so and have had no issues with it. The day I drove it home the DEF warning came on that it was low and I had xxx miles before the vehicle would be disabled so I contacted the dealer and told them. They had me drive it back to check it out and by the time I got to the dealer the warning was gone. Zero issues since.
LubeITMan is offline   Reply With Quote
Old June 26th, 2018, 09:04   #3
jrm
Fuel Economy: 42/52
12-14 are the same (slight changes only) 15 gets the new engine and is quite desirable
2015 Passat TDI SEL
2013 Passat TDI SE+NAV 48MPG (totaled)
2012 Ram 2500 Longhorn 15MPG tops
2009 Highlander Hybrid aka the HIHY 25MPG
1996 Dodge mechanical Cummins 12V 2500 4x4
jrm is offline   Reply With Quote
Old June 26th, 2018, 09:40   #4
goodmonkey
goodmonkey's Avatar
It has been a few years since I drove my '12, but I feel my post fix '14 does lug the engine a little bit more. I'm adapting to move to the triptronic gate or Sport mode when necessary. Considering I bought the '14 with the fix done (nearly a year before) I cannot comment on the car beforehand, but the driveability is still okay. For a true TDI Enthusiest (like yourself and I) I do not see a big issue with a '14 vs a '15. The real differences with warranty vs engine and DSG have been covered many times in the past month even, but I'm not unhappy with mine (I am still happy at this point). Also, I'm not saying anyone else ISN'T a true enthusiest.
The AdBlue level issues I'm not certain cross the '15 line. Maybe someone else can comment on that.
2014 Passat TDI SEL (DSG) - 102k, 2011 Touareg Executive -149k
Previous TDI's: 1996 Passat TDI- totaled at 394k miles, 1998 Passat TDI - 175k miles, 2012 Passat TDI SE - 41k, 1996 Passat TDI Variant - 327k, 2014 Jetta SportWagon TDI 6MT - 29k, 2015 Passat TDI SEL - 18k, 2006 Jetta TDI 5MT - 261k
goodmonkey is offline   Reply With Quote
Old June 26th, 2018, 12:09   #5
jck66
jck66's Avatar
I have a '12 SE DSG and have been seeing a NOx sensor code on mine consistently since getting the "fix". The CEL only comes on when we take the car on a highway trip. Around town we get no light. No apparent difference in DEF usage on the car either.
jck66 is offline   Reply With Quote
Old June 26th, 2018, 14:33   #6
dborja
I got a CEL code P2457, as a couple of people here have had, about 5,000 miles after the fix. Dealer replaced the heater core under the warranty. Otherwise, I noticed the shift points are different and I'm only losing less than 2 MPG. No significant increase in DEF consumption that I can notice.
dborja is offline   Reply With Quote
Old June 26th, 2018, 15:43   #7
06bluebeetletdi
'14 passat tdi sel 62,800 miles. Bought 9/15/17 at 50k, LOVE it. Only a couple minor issues - heater core under extension and water pump under powertrain. I occasionally manually shift when its cold, but i do the same thing with my '13 beetle tdi also DSG.
06bluebeetletdi is offline   Reply With Quote
Old June 27th, 2018, 04:23   #8
740GLE
If you're getting your current car bought back, I'd suggest you find your replacement car at a price you want before the buy back.
Also If I were you I'd be willing to spend a little extra if you find a nicer '15 compared to a 13/14. Going up to a '15 SEL was a reason the wife could see her self driving the "same" car for 10-12 years.
Biggest thing I've seen for issues is coolant related due to increased EGR, as noted by failed heater cores. Other than that no other major issues that your current '13 is already at risk to.
Hers: 2015 Passat SEL (NOS) w/ VW fix and Malone Stage 2 (low torque for DMF shudder).
Old June 27th, 2018, 05:09   #9
roni024
Another vote for the 2015. 2012-2014 was when VW was ironing kinks out of the 2.0 TDI. 2015 was the year they perfected it.
roni024 is offline   Reply With Quote
Old June 27th, 2018, 08:07   #10
rustycat
Yes indeed, another voice to the chorus of go with a 15. Drives far better than our 13 did.
And, if this is any indicaiton, we've had nary a squeeze, rattle or any issue in the first 12K miles with the massively huge improvement in start off lack of turbo lag and less nannied wheel spin.
rustycat is offline   Reply With Quote
Old June 27th, 2018, 10:01   #11
Fastbird
Had the fix done on my somewhat higher mileage 12 just over a year ago now. Fix done at 119.8K miles, now has 135.5K miles. No issues after the fix save for some relearning to my driving style that caused a short term fuel economy drop. After that sorted itself after a couple of weeks, it's been fine save for a (probably unrelated) potentially failing injector causing some noise now.
Fastbird is offline   Reply With Quote
Old July 9th, 2018, 08:52   #12
r90sKirk
r90sKirk's Avatar
Appreciate all the feedback - will see if I can get into a 15 SEL in our budget.
thanks
Old July 9th, 2018, 10:29   #13
Lex Tdi
TDI(s): 2013 Passat
Got the fix done a few weeks ago on my 13 and already racked a few thousand miles. I seriously have noticed no changes whatsoever. So if the 15 doesnt fit the budget... do a steve miller and take the money and run!
2013- Passat SE DSG 190,000 miles
RIP 2003 Jetta - 444,000 miles
SOLD 2001 Jetta - 300,000 miles
Thanks to Paramedick (Bruce) for being my local Guru for over a decade!
Lex Tdi is offline   Reply With Quote
Old July 9th, 2018, 10:59   #14
MichaelB
Fuel Economy: very good
^^^^AGREED^^^^^ I did the same thing got the fix, took the money. No regrets.
MichaelB is offline   Reply With Quote
Old August 5th, 2018, 19:14   #15
mikew85120
Fuel Economy: 34-37 City 44 highway
Default 14 Passat SE TDI
I had the fix about a year ago. I have noticed very little difference in handling or mileage. Hope that helps.
Mike
thanks,
Kirk
mikew85120 is offline   Reply With Quote
Fix for '12-'14 manual, 6sp, passats??!?! J VW Passat Family (NMS and B7) TDIs (2012+) 122 July 4th, 2018 20:53
13 - 14 TDI Down and Midpipe sound antioch01 TDI Power Enhancements 1 March 30th, 2015 13:52
Seeing more 2012/13 Passats on the Road Stimulacra VW Passat Family (NMS and B7) TDIs (2012+) 18 November 29th, 2012 19:34
any issues in early Passats? dmacarthur TDI 101 3 July 24th, 2012 08:06
Issues with Passats and VWoA chippie VW B5 Passat TDIs 14 July 5th, 2009 17:57
© 1996 - 2020, All Rights Reserved
Page generated in 0.18129 seconds with 11 queries
[Output: 125.95 Kb. compressed to 105.04 Kb. by saving 20.91 Kb. (16.60%)]
