Rob Mayercik
Lubed up the seat slider lock pins over the weekend (was having issues with the driver's seat not latching after the mechanic had been in it).
In the process, found that the height adjuster helper spring had "self-deleted" itself, so threw it in the little cubby in the trunk with the other one (the passenger one "self-deleted" itself years ago).
Also, discovered the USB-RS232 adapter I use to make my HEX-COM VCDS cable work with my USB-only laptop wasn't working. Have to see if a recent Windows update or driver install has messed up the settings, or if the thing's just dead after about 5 years. Ah well, that goes on the to-do list for after I get my taxes filed...
