My '02 Wagon is pretty much my daily driver. In May I had the leaking IP replaced with a rebuilt 11mm, and had the timing belt service done at the same time as I was only about 5K short of the interval. Since then my FE has improved a little: I've seen over 50 MPG out of the last three tanks. This includes commuting, some traffic, lots of local driving, some cruising at 80+...a real mix. I don't use the A/C a lot, but I don't see much of a difference with or without it. My last two tanks were over 800 miles, and I can't remember the last time I got fewer than 700 miles. This is with RC3+, stock turbo, PP357s, the aforementioned 11mm pump. Engine now has 100K miles on it, so it's nicely broken in.
Mechanical and tuning setup are key to good FE, as is hardware condition. I'm fortunate to have a guru that's obsessive about getting the car set up right (mr chill here), and I'm a big fan of Rocketchip's tunes. Whatever it is, the combination works.
People wonder why I keep driving this car with 390K on it when I have much newer cars available to me. It's hard to step away from this kind of FE and range.
