Old March 23rd, 2015, 09:10   #1
Pwrtrip
Pwrtrip's Avatar
TDI(s): 2001 Golf
Fuel Economy: 40's
Default Voltage fluctuating on Modulating Piston Movement Sensor
This isnt my car but a friends 2000 Golf.
The IP was replaced with a "supposedly good used one".
What im seeing in the program when i monitor it on my laptop in real time is the QA arm is free and working correctly and in the lower position, but the display voltage is switching back and fourth from .780v to 5.1v and keeps switching back and fourth every 2 seconds. When I manually move the arm to high it stays at 5.1v
Im thinking there is a short somewhere, harness maybe? or could this be the PCM bad? Anyone ever seen this or know what could cause this? Or is it just the QA that is shot?
Thank you.
Saturday,21,March,2015,15:29:59:38112
VCDS Version: Release 14.10.2
www.Ross-Tech.com
Address 01: Engine Labels: 038-906-012-AGR.lbl
Control Module Part Number: 038 906 012 BD
Component and/or Version: 1,9l R4 EDC G600AG 2507
Software Coding: 00001
Work Shop Code: WSC 01317
VCID: 53AB7063A161A8B983D-4B18
2 Faults Found:
17762 - Modulating Piston Movement Sensor (G149)
P1354 - 35-10 - Electrical Malfunction - Intermittent
17970 - Quantity Adjuster (N146)
P1562 - 35-00 - Upper Limit Reached
Readiness: 1 2 1 0 1
Pwrtrip is offline   Reply With Quote
Old April 1st, 2015, 16:54   #2
Pwrtrip
Pwrtrip's Avatar
TDI(s): 2001 Golf
Fuel Economy: 40's
bump. Is this an obvious thing or something way out there?
2001 Golf auto. Stock daily driver
2003 Dodge 3500 6.7 Cummins
Gassers; 72 Nova, 71 Chevelle, 99 Transam
Old April 11th, 2015, 20:18   #3
agtorange
TDI(s): 2000 tdi
Anyone know this problem? "Modulating Piston Movement Sensor (G149)"
agtorange is offline   Reply With Quote
Old April 11th, 2015, 20:31   #4
Pwrtrip
Pwrtrip's Avatar
TDI(s): 2001 Golf
Fuel Economy: 40's
Took another IP and plugged it in and the fault code followed it.
The high and low limit for the QA i know were on the IP.
Old April 13th, 2015, 09:51   #5
agtorange
TDI(s): 2000 tdi
Anyone? need help.. the search button is not helping me tested all wires from pump to computer side and all are intact not broken.
Old April 13th, 2015, 12:03   #6
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
If the timing if off it'll throw 1354 1562 codes.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old April 13th, 2015, 12:04   #7
jasonTDI
jasonTDI's Avatar
If this is the car with the pump install issue in the other thread it's due to the belt tension not being even all the way around the circuit.
... IP's Harness wires to the G149 Modulating Piston Displacement Sensor MrSafety VW MKIV-A4 TDIs (VE and PD) 14 June 17th, 2017 20:39
Fuel leak - Modulating Piston Displacement Sensor popamike54 TDI 101 12 December 27th, 2009 17:04
Piston Movement Sensor G149 VDubbing VW MKIV-A4 TDIs (VE and PD) 3 August 14th, 2008 01:04
G149 :Modulating Piston : No voltage displayed twm OBD Scanners 1 March 10th, 2008 17:52
17762 - Modulating Piston Movement Sensor (G149): MJ1GTTDI VW MKIV-A4 TDIs (VE and PD) 4 September 13th, 2003 22:24
Page generated in 0.13672 seconds with 11 queries
[Output: 80.61 Kb. compressed to 69.91 Kb. by saving 10.70 Kb. (13.27%)]
